Old 11-07-2007   #1
dedlewamp
Drives: 4G63
FS: 1990 Talon AWD Modded, Midwest
The time has come to sell my beloved 1990 Talon TSI AWD, as I will be moving soon and don’t have the space to really enjoy this car for awhile. There is over $17,000 invested in the car, with most of the receipts to show for it. This has the most desirable combo’s for any DSM, the four bolt rear and six bolt motor. You won’t have to worry about crankwalk on this motor, or too weak of a rear end during those 6000 RPM launches.
I am the third owner of this car. I purchased it from a gentlemen who bought it from an older gentleman with 161,019 miles. Everything was original including the engine, showing just how well this car was taken care of.
ENGINE/TURBO/POWER MODS AND UPGRADES TO THE 6-BOLT ENGINE: (Less than 10,000 miles on new engine)
- Forged Eagle Rods
- Forged Ross 8.5:1 pistons
- Clevite bearings
- ARP hardware all around(head studs, mains, and rod bolts)
- Mitsubishi MLS head gasket
- Precision Turbo Engineering 5031RE dual ball-bearing 50 trim turbocharger
- Forced Performance turbo inline oil filter fed from oil filter housing with restrictor
- Ported and Polished 1G cylinder head
o Forced Performance FP2 camshafts
o 1mm oversized valves
o Titanium springs and retainers
- Extreme Turbo Systems 10.5” race intercooler kit
- Greddy Type RS with recirculation kit
- TurboXS manual boost controller
- -Balance shafts removed
- New Mitsubishi front cover, knock sensor, O2 sensor, water pump, oil pump, hoses, and drive belts.
- New Mitsubishi timing belt and tensioner
o Installed when the new cylinder head was put on, less than 3,000 miles ago
EXHAUST
- Magnaflow 3” catback exhaust system
- Gutted high flow catalytic converter
- 3” downpipe
- Ported 2G exhaust manifold
INTAKE
- 2G MAS
- Custom 4” cold air intake
- K&N high flow air filter
- Dejon Tool 3” intake
SUSPENSION
- KYB GR2 shocks/struts
- Front/Rear anti-roll bars
BRAKES
- TurboTrix big brake upgrade
o Upgraded the tiny single piston calipers to larger dual piston calipers, larger slotted rotors in the front, as well as better pads, and stainless lines all around.
TRANSMISSION/DRIVELINE
- Shepherd Racing transmission
- Rebuilt transmission by John Shepherd. Transmission was fully rebuilt, replacing anything that needed to be replaced. Also installed was a 4-spyder differential using a brand new center differential from Mitsubishi
- 1992 shifter cables and shifter base
- Skate shifter bushings and solid transmission bracket
- ACT 2600lb clutch
- Raxles.com front axels
- Clutch assembly has been taken out and welded to remove any play in the pedal
- 4 bolt rear end
- New Mitsubishi master and slave cylinders
GAUGES
- Greddy EGT
- Autometer Boost
- AEM Wideband
IGNITION
- Accel 8mm plug wires
- NGK BR7ES spark plugs
FUEL
- 850cc Fuel Injector Clinic injectors
- Machined stock fuel rail
- Aeromotive fuel pressure regulator
- Walbro 255lph intake fuel pump with rewired main supply
- Stainless braided lines from fuel rail to filter and return
- Brand new Mitsubishi fuel filter
ETC
- DSMLink
- Fluidyne high performance all aluminum radiator
- Brand new Craftsman battery with warranty
o Relocated to rear of car
- Dual 12” electric fans, one puller, one pusher
- 1990 EPROM ECU
- Professionally tinted rear windows
- Pioneer CD head unit
- Upgraded front speakers
- Tons of other details(transfer case leak fix, carrier bearings fixed, gaskets, hoses, etc.)
Overall the car is in excellent condition. The car has never been smoked in, and always stored in a garage. Since I’ve owned it, it’s never seen snow. There is absolutely no rust on the body, and only minor surface rust on the undercarriage. Most of my time and money has gone into making the car fast and reliable, so I’ll list out possible issues with the car that the buyer may have.
- The paint. The car has the original paint. It looks great for a 17 year old paint job, but by no means is it perfect. The fenders are beginning to have some clear coat fade. The side panels are all straight, but have numerous parking lot dings. The hood appears to have been repainted, but not very well. With that being said, it still looks great, but it would be up to the buyer if it bothered them enough to paint it.
- Interior. The front interior is in excellent condition again for a 17 year old car. Seats are in perfect condition, carpet is clean, dash is good. The rear of the car has been gutted from the front seats back. I still have all of the plastic, carpet, and seats that can be included with the sale if requested.
- Air conditioning has been removed. Car retains power locks, power brakes, power steering, cruise control, heat, and power windows.
- Emissions. Car will not pass emissions in current state. Many emission controls in engine bay have been removed, along with missing catalytic converter.
Car is currently running at 20lbs of boost. It’s still relatively untuned, so there is a lot more potential in the car. A setup like this is capable of easily running 28+ lbs of boost and an 11 second timeslip. It starts right up just fine, runs cool, and even gets decent gas mileage if you stay out of boost. Always used Mobil 1 oil and filters every 2500 miles. New fluids in the transmission, transfer case, and rear end.
Of course, there is no warranty of any kind on the vehicle or any of the parts on the vehicle. I do certify that the odometer reading has never been tampered with by myself, and have a statement from the previous, original owner that he has never altered it either. The odometer still reads the total mileage that has been put on the car, not the new engine. I have put less than 7,000 miles on the car since I owned it, so many parts have even less miles on them. Also I will include a brand new set of tires for the stock rims FREE if we get a deal made in the next week or so. They are Eagle HP’s, in the stock size. Cost $400+There is no major mechanical issues that I know of. Car drives straight, no unusual sounds.
The car must be picked up, and PAID FOR WITH CASH OR A CERTIFIED BANK CHECK. I will not part out anything, as I just don’t have the time right now to remove parts and ship everything. Not looking for auto trades. Located in Iowa, zip code 50010. Please respond to this thread and PM if you are interested. I'll PM you my phone number if you'd like to talk, or even setup a time to come look at/drive the car.
With that being said, I’d like to get $6,500 or best offer for this. You’re getting a nice six bolt/four bolt 1G, $17,000 worth of after market and OEM goodies, and one of the best AWD platforms out there on a budget.
dedlewamp is offline   Reply With Quote
