Old 11-16-2007   #1
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Master & or Slave
My clutch master & or slave went bad today! I had to take the work beater truck home! I tried bleeding it with no luck. tried twice. The fluid that came out at first was pretty black as was the stuff in the reservoir. I started by sucking most of the fluid out of to start with all new fresh fluid. & bled it till it had no air & the fluid was clear... still no luck, so I think I need a new master cylinder & I might as well do the slave @ the same time. Grrr what fun!! Do you think I can get the parts @ O'Reillys? Do you have any other ideas why I can't get it in gear.
Thanks!
ESchwanz is offline   Reply With Quote
