Old 02-22-2004   #1
Dutch_DSM
Today i was finally able to try and start up my '90 TSI again after I replaced a spun bearing. (new crank & rod)
The car will start but is running really rich
and the stock boost guage is way off.. showing boost on idle.
I was thinking the MAF but when the ignition is on the stock guage is on 0 like it should be
And when I push the throttle a bit the stock guage goes up all the way to max boost and offcourse the car blows out some black smoke and stalls because it's running really rich.
Any idea's what could be the problem?
Can it be a vacuum hose? because i had all disconnected
The ecu was also out of the car to have the capacitors fixed.
Mods: None car is stock!
