Old 11-30-2007   #1
5speedfox
1991 Mustang Gt 5-speed
http://minneapolis.craigslist.org/car/490559737.html
first...No rust..underside is very clean. there are a few issues with this car. First, it's not tuned, second the gears have chip on the coast side so when you coast it makes a "click click click..." noise. The heater core is bypassed I plan in fixing that this weekend. Also you have to play with 4th a little to get it out, not bad just a little. So if your interested let me know. It has about 180,000KM on it, which i think is around 110,000 miles. it's got:
  • New Paint Car had faded white paint, repainted with PPG base/clear I have the paint code in the car but it's a 200X Gm color.
  • 75mm Maf
  • 70MM tb
  • 24lb injectors
  • Trick Flow Street heat Intake
  • Trick Flow 1.6 RR's
  • Trick Flow Track heat heads with upgraded springs
  • Trick Flow Stage 1 Cam
  • ARP head bolts
  • Warbro 255 Fuel pump
  • TKO-500 Trans
  • B&M short shifter
  • Aluminum Drivshaft
  • Rear 5th link
  • Kyb shock with really low springs
  • Rear disc Conversion
  • 6 point roll cage
  • Subframe connectors
  • Electric Fan
  • Big Aluminum Radiator
  • BBK shortie Headers
  • BBK Off road H-pipe
  • Msd ignition
  • Flowmaster 40's
  • Ford Racing 3.73 gears
  • Cobra R 17in wheels
  • Nitto Drag Radials
Handles like a dream.
5speedfox is offline   Reply With Quote
