Old 12-20-2007   #1
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Pulling timing?
92 talon tsi AWD.
When I'm accelerating, the engine gets louder, the RPMs stay the same and the boost gauge says it's boosting but the car doesn't move any faster. If anything, it moves slower.
It's obviously getting spark air and fuel.. so what is the problem? The only thing left is timing right? Ideas? Suggestions?
- Josh L.P.
Old 12-20-2007   #2
Re: Pulling timing?
Is this a real boost gauge or the stock one? It could be running really rich too. Does it sputter or miss or anything?
Old 12-20-2007   #3
GnArKiLl
GnArKiLl's Avatar
Re: Pulling timing?
hahaha my car was doing the same thing tonight!! it turned out to be the gasket on the j-pipe...
Old 12-20-2007   #4
Re: Pulling timing?
Slipping clutch? Broken axle?
Old 12-20-2007   #5
Pimpin Dsmstyle
Br0k3N
Re: Pulling timing?
Like I said, the RPMS do not go up when the engine gets louder. The RPMS would increase for a slipping clutch and broken axel.
It's the stock boost guage but the engine sound is pretty on with the boost increase according to the stock gauge. I know it's not accurate but it sure sounds like the motor is boosting.
It spudders and what not at higher rpms and occassionally while this shit is going on but it's mostly just a huge power loss with the sound of acceleration.
- Josh L.P.
Old 12-20-2007   #6
Pimpin Dsmstyle
Br0k3N
Re: Pulling timing?
It does almost feel like a boost leak. It's just weird that it does it when it feels like it. Sometimes, I can let off the gas completely, go WOT and the problem goes away for that pull.
- Josh L.P.
Old 12-20-2007   #7
Re: Pulling timing?
Sounds like a boost leak or bad plugs/wires.
Old 12-20-2007   #8
Pimpin Dsmstyle
Br0k3N
Re: Pulling timing?
What symptoms would one have from having their CAS 180 degrees off?
- Josh L.P.
Old 12-20-2007   #9
GnArKiLl
GnArKiLl's Avatar
Re: Pulling timing?
my car was doing the exact same thing last night.. check the j-pipe gasket and the tb gaskets
Old 12-20-2007   #10
Re: Pulling timing?
The car wouldn't run for crap, that isn't it.
