Old 01-28-2008   #1
green hornet
another 6 bolt swap Q
so i think i have every thing i am going to need, the one thing that i have been woundering about is if all the sensors on my motor will hook right up to my 2g. i know i need to do some cuting for the CAS but other than that every thing should hook up right!
Old 01-28-2008   #2
Re: another 6 bolt swap Q
I was told to use all the 2g sensors on the 6 bolt motor.
2g TPS (has 4 pins vs 3), oil pressure, water temp sensors, knock sensor, etc.
The exception would be the 1g CAS which hooks up to the 2g plugs for crank/cams.
I'm not sure if any are the same between 1g and 2g, something like water temp or oil pressure may not have changed.
Old 01-28-2008   #3
They should all hook right up. The crank sensor won't be on the new engine, so keep that in mind. If you put DSMlink in, then no worries.
Old 01-28-2008   #4
dragonforce
I just finished mine. i used 1g head, 1g intake, and 1g oil pump assembly. i had to t-off vacuum lines for map sensor. used 90 cas and 1g TB. swapped the spark plug wires and injector wiring at ecu.
dragonforce is offline   Reply With Quote
