Old 02-21-2008   #1
Shane55113
Now 20% less Racist
Shane55113's Avatar
halfshaft (axel) spacer, a/c bracket
Hey all, i had a really hard time with my halfshaft breaking bolts off in the block, i soon figured out that when i removed the ac bracket it acted as a spacer for the halfshaft.
To fix this you can buy a spacer from mitsubishi that takes up the slack so you don't keep breaking the bolts, here is the part number: MB297732 (spacer, fr axel) it will be a special order part number.
Or here is the dimensions of the spacer if you want to make your own
(its a circle) outer diameter:22mm inner diameter: 10.6mm thickness: 8mm
I had one hell of a time finding this spacer so i hope this helps someone.
