Old 03-02-2008   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Electrical starting and running problems
My car was doing find throughout the winter till this happened...
A couple of days ago my car was having weird starting problems and the symptom is that the starter was ticking
First thought the battery was dead but jumpstarted it and battery was fine. Didn't take any power like a worn down battery... plus seatbelts were moving at correct speeds and lights were bright so then I didn't think it was the battery.
Then replaced the starter but second starter that I put in did the same thing...
Played with some of the cables going to the battery, nothing (I should say now the tach was doing something weird at this point and it was bouncing to 4000rpm and back down again) and then walked away fustrated... came back one last time to try to start it and it turned over and started up like nothing had happened...
Drove it home (was in the MOA parking lot) and parked it. Turned the car off and tried to start it again and ticking came back and tach bouncing. I thought it could be the connections (weren't tight enough) and bought new (good) clamps to the battery posts. Still ticking, replaced the fuses, still ticking, moved some cables around and started normally again.
Shut it off because now I thought it wasn't reliable to drive anywhere.
So yesterday I tried to start the car and now it was starting, ran for 2 seconds and dies. Try to restart it, ran for 2 seconds... die, and so on.
So at this point I am scratching my head trying to figure out what is going on or even how to attemped fixing this problem.
What should I even start with?
I don't think is the battery, but will still go in and have it checked (it is a sealed battery that is relocated in the trunk)
Short to the starter? but why is it now starting running and shutting off
I can hear the fuel pump running (walbro) and so I don't think it is fuel pressure but will check the pressure getting to the engine later
ECU- I never had one go bad on me before and I don't think the starter is even part of the system. Could be related to running problem
Tach problem- this recently showed up so I am thinking this is part of the problem- 1990 ECU system and I can't remember how it gets it tach signal but I thought it got it a different way from the 91-94 1Gs.
So where do I start?
