Old 03-11-2008   #1
gstjoker
gstjoker's Avatar
Send a message via MSN to gstjoker
Angry Sun Roof Stuck Opened?
I have a 2g gst. I decided to open up my sun roof yesterday and for some reason, it's stuck opened now. When I try to press the button to slide it back, it'll slide back like 1/2 inch or so then slide back out itself. I didn't get the chance to check the fuse or what not but any of you guys ever had a similiar problem or know how I can fix this?
Stupid is as stupid does :eek:
gstjoker is offline   Reply With Quote
Old 03-11-2008   #2
Re: Sun Roof Stuck Opened?
Is it possible that something got jammed in the track? Look for some ice, a small rock, etc.
Old 03-11-2008   #3
I used to have that problem with mine, seemed like an electrical problem with the switch at first. Then I disassembled the sunroof, cleaned out the tracks and everything, and it works much better now.
Old 03-11-2008   #4
gstjoker
gstjoker's Avatar
I'll have to check that out later when I get home tonight as I am still at work right now. I just hope it doesn't snow tonight.
Old 03-11-2008   #5
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
sometimes I have to give mine a little help if i remember right.
pics or gtfo
Old 03-11-2008   #6
DSM_421
I've always heard that in some cases you can mess your sun roof up by opening it during the winter time.
Old 03-11-2008   #7
dragonforce
you can manually close sunroofs by turning an allen bolt. i'm not sure where it is located on 2gs.
dragonforce is offline   Reply With Quote
Old 03-11-2008   #8
bluntedelvis
Click,Click,BOOM!!!
bluntedelvis's Avatar
I had the same thing happen to me last fall. So I ripped apart my switch and cleand it up a little on the connections havent had a problem since.
Old 03-12-2008   #9
BuildADSM
to do it manual there is an access pannel near the switch. Open the pannel and check it out.
