Old 03-21-2008   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
FS FP 20g TD06H Model Turbo
I have a FP 20g TD06H Model Turbo. I bought it last year and put on maybe 1500 or so miles and the guy before me had it rebuilt before he sold it. It has a little shaft play but seems like the normal amount. Upgraded so need to sell. There is one small crack that was welded but cracked a little futher but not major. It is setup for an external wastegate off of the o2 housing or I have a flap that you can weld in the stock wastegate hole to run off of the manifold or however you want. Send me an offer on this as I am not sure what it is really worth. Don't give me BS offers either. Thanks for the space. It is a real 20g and not a fake and is the largest one made. It is all factory mitsu flanges and will bolt right up to and 4g63 with water and oil cooling just like a t25 or a 14b. It also does NOT hit or come close to the water pipe. It has a 3" intake and a 2" outlet. It is also ported where the exhaust goes into the turbo by the o2 outlet for better lower boost control. $550 or B/O
Amsoil Dealer
Old 03-28-2008   #2
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: FS FP 20g TD06H Model Turbo
Is anyone interested in this? Ill take reasonible offers on it.
Amsoil Dealer
Old 03-28-2008   #3
turbo-soundz
Questions....
1. Whats the highest boost you set on this turbo?
2. Why did it cracked?
3. What turbo you upgraded to?
4. Full Boost? Where at the RPM it lagged?
5. Feedbacks on turbo, your experience.
turbo-soundz is offline   Reply With Quote
Old 03-28-2008   #4
95talonracer
Finally Tuned...
Drives: Spyder GSX
Originally Posted by turbo-soundz View Post
Questions....
Well I ran around 33psi on it.
I have no clue why it cracked but it isnt that bad at all.
I upped to an SCM61
I think full boost is a bit over 35psi and I seen full boost around 4200
I love it but want more power!!
Send offers people I need it gone!
Amsoil Dealer
Old 04-06-2008   #5
95talonracer
Finally Tuned...
Drives: Spyder GSX
Sold!
Amsoil Dealer
