Old 03-24-2008   #1
kennydawgg
crank grind
what is the max that a crank can be ground down and still be useable? I have a 64 crank thats chewed up on on spot, would like to reuse it if or sell it, I just hate to see it go to waste.
kennydawgg is offline   Reply With Quote
Old 03-25-2008   #2
dumb_ricer
Hates Everything
Drives: Neon
Re: crank grind
Turned 4G63/4 cranks are the devil!
420A > LS1 > All Else
I > All else
Old 03-25-2008   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: crank grind
+1... I've heard of some people having success but I wouldnt trust it!
Originally Posted by shoutbox
Old 03-25-2008   #4
Re: crank grind
.010. Some people have no problems, most do.
Old 03-25-2008   #5
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
Re: crank grind
I had a crank turned went to hell 50 miles after i put it in needed to replace the block and oil pimp because of the thrust bearing failure.
Old 03-27-2008   #6
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: crank grind
If you get it done defiantly have it nitride treated after.
Old 03-27-2008   #7
blageo23
AWD4G64
blageo23's Avatar
Re: crank grind
I had mine turned down 10 under and got it nitride coated and has been working for me since, only 1500 miles but still holding up(knock on wood)
1998 Spyder AWD
567hp
490tq
