Old 04-09-2008   #1
Capinoy123
Capinoy123's Avatar
Drives: A paint faded Red/pink/black 90 eclipse. Collector Plates!
Tourqe specs?
Does anybody have all the tourqe specs for the 4G63T motor? Or know where i can get them besides the gay chiltons or haynes manuals?
Best E.T 10.5 @ 137 on 30 psi, E-85 and street tires! (never dyno'd)
Capinoy123 is offline   Reply With Quote
Old 04-09-2008   #2
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
Re: Tourqe specs?
www.vfaq.com has some specs, but they're hard to find.
Try www.plymouthlaser.com for some of them.
I believe there is a "CAPS" out there for DSM's. But I can't find the link anymore.
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 04-09-2008   #3
mdost03
Sonic Champion!
Drives: VA STI
Re: Tourqe specs?
What's wrong with Haynes manual?
Old 04-09-2008   #4
Re: Tourqe specs?
CAPS is a parts lookup program that Mitsu uses, lots of us have it. It doesn't have torque specs. Use the Haynes, it's fine.
Old 04-09-2008   #5
User Name
User Name's Avatar
Re: Tourqe specs?
Ahh, Thanks. Could you link me to it? Or somebody? I could use this.
ForSale:
FIC 850
FP Turbo kit
Old 04-09-2008   #6
Capinoy123
Capinoy123's Avatar
Re: Tourqe specs?
ok i guess the haynes manual will do..
Old 04-09-2008   #7
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: Tourqe specs?
If you want to come down to eagan im sure i can print them all off for you using Mitchell On Demand. Otherwise just buy a haynes this most likely wont be the only time you will need these specs.
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 04-12-2008   #8
Re: Tourqe specs?
How about the DSM cd? or what were you looking for?
Old 08-16-2008   #9
joesushi
Smells Like Fish
joesushi's Avatar
Drives: 96GSX
Re: Tourqe specs?
In my chiltons manual it doesnt state a final torque spec for the crank bearing caps. it uses a low torque value then says finish with a 1/4 turn. I am looking for the torque specs on:
crank bearing caps
rod bearing caps
and the recommended torqueing sequence when using a stock mitsu composite headgasket.
Old 08-17-2008   #10
Re: Tourqe specs?
All that info is in the Chilton...
Old 08-17-2008   #11
Re: Tourqe specs?
What year engine and are they factory parts you are installing?
Old 08-17-2008   #12
brando
Drives: gutlass
Re: Tourqe specs?
always use a chilton manual. hayne's sucks. they leave stuff like that out
Old 09-06-2008   #13
CarPsyco84
CarPsyco84's Avatar
Re: Tourqe specs?
alldatapro told me 34-36 ft lbs for the rod caps...
-When in doubt, Moar RPM.
