Old 04-16-2008   #1
Spring Dyno Day Mods! Who's doing what!?!?
I'm toying with the idea of dynoing my evo, still not sure. If I do, it will be interesting.
Last dyno @ DB, 304whp @ 24.5psi on 1/2007
Since then added:
SS o2 housing
Ported turbine housing
Ported Exhaust manifold
IX turbo
GM BCS, upped to 26psi
Ported intake manifold
65mm throttle body
Kraka Vents (TM)
I have an evo X MAP sensor on order. If it comes in time, I might make the plunge!
Old 04-16-2008   #2
Re: Spring Dyno Day Mods! Who's doing what!?!?
Hmmmm...nothing!
Old 04-16-2008   #3
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
I am going to add an O2 housing, cone filter, and hopefully some decent cams.
Scheides, I need your help with my ECU.
Old 04-16-2008   #4
Jungy
Jungy's Avatar
Sine the last time may car was dynoed (222 fwhp pump gas) this is what has been added:
e85
built bottom end
60mm throttle body
Hanh S20g Turbo
Hahn 3" Downpipe
Hahn 3" Racepipe
Thermal Research 3" Cat Back Exhaust
Greddy Type-S BOV
Greddy Profec B-Spec II
Aeromotive 1:1 FPR
Walbro 255lph Fuel Pump
Accell In-Line Fuel Pump
Ross Racing -6 AN fuel rail
880cc Injectors
Megasquirt
Crane #14 Turbo Cams
Crane Valve Springs
Crane Titanium Retainers
3.55 Trans
Quaife LSD
Spec 5 Clutch
I'm interested to see what it'll put down
Old 04-16-2008   #5
My car: nothing
My bike: Never been on a dyno, so it'll be interesting.
If weather permits, I'll be bringing the bike.
Old 04-16-2008   #6
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
we'll see how my car is running by then but nothing special just same old stuff.
Old 04-16-2008   #7
if I have time to do it
8an fuel lines
and a quick street tune.
other wise the car will not hit the rollers
Old 04-16-2008   #8
DSM_421
Last time my car put down 282.2 @ 20 psi at DB
I hope to be able to walk within the next week and get my 3" Megan TBE w/ test pipe and LIPP cast o2 Housing on by dyno day.
That would be to replace my ported 2g o2 housing, my 2.5 inch downpipe, and really restrictive 3" pressbent exhaust that has many bends in it.
Old 04-16-2008   #9
I'll finish putting in my front components, mount the amps and build a custom box for the subs.
Old 04-16-2008   #10
Wow i didnt know they were having Db Drags as well. lol
Old 04-16-2008   #11
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
If I dyno. New Mods will be 150# injectors and a 30+ psi street tune. hopeing for 500+ FWHP
11.35 @ 120mph
Old 04-16-2008   #12
Last time at the dyno i put down almost 300, so this time with all the mods i am hoping for a little more.
Old 04-16-2008   #13
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
I got a new turbo and a new clutch that will hold my power on the dyno now. Hopefully its done by then.
Amsoil Dealer
Old 04-16-2008   #14
311evo
311evo's Avatar
I'll hopefully be getting some fresh paint, and a rent-tux. same day as prom woo!
Old 04-17-2008   #15
merkzu
I'll be running my craptastic tune for Holiday winter E85. I made 380whp last time, will be less this time
merkzu is offline   Reply With Quote
Old 04-17-2008   #16
I won't be there to shit in everyones wheaties like 2006
Good luck everyone!
Old 04-17-2008   #17
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
last time I dynoed I made 265awhp. Since then I've added a bigger intake and a new clutch. If I decide to put my 1000s in I'll be running e85, but I'm really having a hard time deciding if I want to or not. idk if making more power is worth breaking more things lol.
pics or gtfo
Old 04-17-2008   #18
DSM_421
I'd say throw the 1000s on and let er buck with some e85. With the power you are making you shouldn't have to worry about breaking parts. Maybe walking a crank though!
Old 04-17-2008   #19
HiImBrian
HiImBrian's Avatar
^main this is idk if I want to go through with all that. When I go to sell my car idk if it'll be easier or harder to sell a dsm on e85 or not. idk we'll see.
pics or gtfo
Old 04-17-2008   #20
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
never know.. might be easier. If i can get the talon fixed by then i believe ill try and bring my 91 Talon Awd - pte50 trim- 660's. afcII - 23psi ect. New clutch , master and slave. Also hopefully getting the turbo rebuilt by then, have a quick street tune and let her buck.
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
