Old 04-18-2008   #1
evoeater13
Drives: Plymouth laser rs awd
fuel problem
im having trouble with my 92 laser i just put 650 injector it runs like shit when i give it WOT i have a 16g turbo super side mount and 3in turbo back done to it .so i dont know what to do to fix this problem im new do having a dsm
evoeater13 is offline   Reply With Quote
Old 04-18-2008   #2
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: fuel problem
What are you using to control the larger injectors?
Old 04-18-2008   #3
Re: fuel problem
^good fucking question
Old 04-18-2008   #4
evoeater13
Re: fuel problem
nothing and i just drove the car home from my work and the manifold and the turbo where glowing red
Old 04-18-2008   #5
Re: fuel problem
You need some way to control the fuel injectors! The only Evo's you will be eating are the ones in lots of pieces torn apart in a garage.
The cheapest/easiest way for you to solve your problem is buy a S-AFC (any of the many varieties) and have your car dyno-tuned at DB. Right now, your car is running WAY rich.
Old 04-18-2008   #6
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: fuel problem
if you looked at it during the night, it would be glowing red. They get that hot.
Old 04-18-2008   #7
Re: fuel problem
650s are overkill for that turbo also. But you atleast need some thing to tune it, whether is be DSMLink, a chipped ECU or just an S-AFC. 550s would work better with an SAFC though, the SAFC isn't the greatest when you get into injector that are bigger than you need.
Old 04-18-2008   #8
DSM_421
Re: fuel problem
Contract ecoli, the guy above my post. He can help you out a lot. Like everyone said get a S-AFC for a couple hundred and then go to ecoli for the tune. Will also be a few more hundred.
Those are two essential things that need to be done when running more boost / bigger injectors.
Good luck!
Old 04-19-2008   #9
Re: fuel problem
I just un-installed my S-AFC, it's for sale if you decide to go that route
Old 04-19-2008   #10
evoeater13
Re: fuel problem
yea how much do u want for it. i got some bigger problems now i had a little fire under the hood after i put the stock injectors in so i got to do a little rewiring to do now
Old 04-19-2008   #11
Re: fuel problem
^nice, don't throw parts at the car, do maintenance do research.
Pay shane to do a tune.
