Old 04-20-2008   #1
sleepy2lazy
sleepy2lazy's Avatar
Coolant Light~!
My stupid coolant tank light in the dash is on and won't go off!!!
I just replaced the coolant temp sensor.
Thermostat has been replaced last fall. Coolant Tank is at Full. Car runs fine, not overheating or anything.
What else could be the problem? i'm hoping it could not be the wire / plug.
Last summer, the coolant tank light would come on and off.
Any ideas guys?
Old 04-20-2008   #2
Re: Coolant Light~!
Isnt there more than one coolant sensor, one used for a/c?
Old 04-20-2008   #3
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Coolant Light~!
I have this problem too. Only difference is mine effects the way my car idles sometimes.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 04-20-2008   #4
sleepy2lazy
Re: Coolant Light~!
There's another one for the A/C? I have not heard of that before. Shed any light anyone?
Old 04-20-2008   #5
Re: Coolant Light~!
As far as I know the coolant light is only triggered by a low coolant level in the overflow bottle. If the bottle is full and the light is still on there is probably something wrong with the sensor on the tank. Either replace that sensor or just pull the bulb.
Old 04-21-2008   #6
Re: Coolant Light~!
Yea the coolant temp sensor is on the thermostat housing, but the coolant light sensor is at the bottom of the overflow tank on a 1g, correct?
Old 04-21-2008   #7
Re: Coolant Light~!
Yup. Two coolant temp sensors on the thermostat housing (1 for ECU, 1 for dash gauge) and then another temp sensor on the radiator for the fan.
Old 04-21-2008   #8
Re: Coolant Light~!
I had this same issue in my old 2G. I removed the overflow tank and cleaned it up best I could, made sure where the sensor is was nice and clean. That fixed it for me.
Old 04-21-2008   #9
sleepy2lazy
Re: Coolant Light~!
Sounds good, i'll try that later after work.
But if that doesn't help, they do sell the tank sensors at Autozone, Napa, Mitsu and what not right? I can't seem to find it at all on their webpages.
