Old 04-24-2008   #1
merkzu
max turbine flow
Not sure if this is a stupid question or not.. I've seen lots of compressor maps posted around, but no turbine maps. I know there is a point where turbine flow basically flatlines above a certain exhaust pressure - that would cause the compressor wheel not to accelerate any further, and exhaust backpressure to increase, right?
If you were trying to get maximum airflow out of a smallish turbo, would it be reasonable to have an exhaust pressure controlled wastegate, set to bleed off excess exhaust pressure but hold enough to keep the turbine near its maximum flow rate?
For example on my 16G I have the wastegate shut off (100% duty on my solenoid) after 5500rpm. Is there excess exhaust backpressure I could get rid of without slowing down the compressor?
I couldn't find a single turbo set up this way so there I'm guessing theres a good reason it's never done this way.
merkzu is offline   Reply With Quote
Old 04-24-2008   #2
Re: max turbine flow
Yes it will create more exhaust back pressure, but it also means the turbo is flowing more. There isn't really a wall, just a point of diminishing returns. You wouldn't want to vent that back pressure, it is doing some good.
Old 04-24-2008   #3
merkzu
Just wondering if its possible to hit a point where venting the pressure would do more good than keeping it against the turbine.. like for this 30R map
After a ratio of 2.0 it can't flow any more. I have no idea what kind of backpressure actually builds up, so is it just that you never reach that point?
Old 04-24-2008   #4
merkzu
I found a post by a guy that measured the pressure before the turbine on an evo turbo:
http://forums.evolutionm.net/showthread.php?t=327719
48psi at 7krpm, he didn't measure the other side of the turbine though
Old 04-24-2008   #5
Take maps with a grain of salt, they are guidelines. Compressor maps are the same way, I have seen turbo's flow much more than what the map shows they should be able to.
Old 04-24-2008   #6
merkzu
I tried lowering the boost solenoid duty cycle 10% from 6000rpm up and boost stayed the same, not sure if it helped anything though or if its even actually opening the wastegate at all.
Just bored at work today
Old 04-24-2008   #7
The WG is likely fully open at that point anyway.
Old 04-24-2008   #8
There is a simple solution to the backpressure problem, a bigger turbo.
