Old 06-05-2008   #1
GnArKiLl
GnArKiLl's Avatar
another e85 question
i did some searching but didnt realy find the answer i was looking for. but would running 50/50 e85 and pump 92 hurt my motor in anyway? the car is still on stock fuel system with rewired pump, 14b, fmic,3" exhaust. just the basics for right now. i ran one tank of 50/50 and i noticed it ran alot better under boost so i want to keep running this but just want to make sure.
Old 06-05-2008   #2
Re: another e85 question
Don't do it unless you get tuned for it. End of story!
Old 06-05-2008   #3
^word, its tough because you will have to maintain a close mixture to what the tune is, that and the changing blends every month and the different octane because of how long it may of sat. Good luck if you go this way there are a few people that do it.
Old 06-05-2008   #4
I don't get why people would want to run a blend of e85 and regular fuel. I think it would be too much trouble trying to maintain a consistant blend.
Old 06-05-2008   #5
GnArKiLl
GnArKiLl's Avatar
ok so what would be the best way to set up for e85? i dont want to run crazy amounts of boost 20psi max for right now.
Old 06-05-2008   #6
depends on turbo size and injector size. 880s were good for a 16G at 27psi.
Old 06-05-2008   #7
GnArKiLl
GnArKiLl's Avatar
well i have a 50 trim just waiting to go on. and im going to run my twin 255 intank setup. what injectors would be good?? and what size fuel lines would i need from tank to filter? and where could i get the line?
Old 06-05-2008   #8
Tank to filter, stock lines should be good enough. If you're running Link, 1600's would be a good choice. That way you don't have to upgrade later on.
Old 06-06-2008   #9
stikx
Mr -
What's your setup other than the 50 trim. Having the right combination of parts is the first thing you shoud think about, then e85.
