Old 06-11-2008   #1
v8klla
v8klla's Avatar
MAPerformance Inventory Clearance Sale *Updated / More Items*
As you may or may not know we are moving to a much larger space on July 1st of this year and we would rather sell this inventory than move it! This is a one time deal guys, check out the list below and contact us for pricing before it's too late!
ACL Honda Thrust Bearings
ACL Race Rod Bearings / 6 Bolt DSM / Standard Size
ACL Race Rod Bearings / Subaru / 52mm Rod Journal / Standard Size
ACL Race Rod Bearings / Subaru / 48mm Rod Journal / Standard Size
ACL Race Main Bearings / 6 Bolt DSM / Standard Size
ACL Race Main Bearings / 6 Bolt DSM / .25mm
ACL Race Main Bearings / Early 7 Bolt DSM w/Integrated Thrust / Standard Size
ACL Race Series Main Bearings / '97+ DSM & Evo
ACL Race Series Main Bearings (Honda D Series / H22A4 / F23)
ACL Race Main Bearings (Toyota/Lexus 1UZFE/2UZFE)
ACL Race Series Main Bearings / Subaru EJ Series / #5 Thrust Position
ACL Race Series Main Bearings / Subaru EJ Series / #5 Thrust Position / Extra Oil Clearance
ACL Race Rod Bearings (Toyota/Lexus 1UZFE/2UZFE)
ACT Street Disc / DSM
ACT 4 Puck Solid Disc / Evo
ACT Streetlite Flywheel / 6 Bolt AWD DSM
ACT Streetlite Flywheel / 7 Bolt AWD DSM
ACT Streetlite Flywheel / Evo
ACT Prolite Flywheel / Evolution VIII IX
ACT Streetlite Flywheel / STi
ACT 6 Puck Sprung Disc / DSM
ACT Heavy Duty Clutch & Flywheel / 6 Puck Sprung Disc / SRT-4
ACT Xtreme (2600) Pressure Plate / DSM
ACT Maxx (2900) Pressure Plate / DSM
ACT Heavy Duty Clutch Kit / 6 Puck Sprung Disc / Evo 8 & 9
ACT Heavy Duty Clutch Kit w/Street Disc (Evo)
ACT Xtreme Clutch Kit / 6 Puck Sprung Disc / Evo 8 & 9
ACT Xtreme Clutch Kit w/Street Disc (Evo)
ACT Heavy Duty Clutch Kit / 6 Puck Sprung Disc / 02-05 2.0l WRX
ACT Heavy Duty Clutch Kit / Modified Street Disc / 02-05 2.0l WRX
ACT Xtreme Clutch Kit / 6 Puck Sprung Disc / STi
AEM Bosch UEGO Replacement Sensor
Aeromotive A1000 EFI Adjustable Fuel Pressure Regulator / -6AN
Apex'i Neo Air/Fuel Controller
Apex'i Auto Timer / Black
ARP Rod Bolts / Pre '94 DSM
ARP Extended Length Flywheel Bolts / DSM & Evo
ARP Balancer Bolt / 4g63
ARP Head Studs / 6 Bolt DSM
ARP Head Studs / 7 Bolt & Evo
ARP Main Studs / 4g63
ARP Head Studs / Subaru WRX & STi
ARP Extreme Duty Head Studs / 6 Bolt DSM
Autometer Replacement Bulb and Socket / No. 168 / 4.9 Watt
Autometer Tubing and Line Kit / 10' Long 1/8" Diameter
Autometer Replacement Bulb and Socket *Replaces bulbs 161, 193, 194, and 168 only
Brian Crower Valve Springs and Retainers / DSM & Evo
Brian Crower Stage 2 Camshafts / Evo 8
Brian Crower Stage 3 Camshafts / Evo 8
Brian Crower Stage 3 Camshafts / Evo 9 MIVEC
Brian Crower Valve Springs & Retainers / Subaru EJ Series
Brian Crower Stage 2 Camshafts / EJ205 WRX
Brian Crower Stage 4 Camshafts / EJ205 WRX
Brian Crower Stage 3 Camshafts / EJ257 STi
Booger Shifter Bushings / SRT-4
CHM Fuel Pressure Gauge
Clevite Rod Bearings / 2g DSM & Evo / .50mm
Clevite Main Bearings / 95-96 DSM / .50mm
Cobb Tuning Exhaust Hangers / Subaru
Cobb Tuning AccessPORT / Subaru WRX 2006-07 / Subaru STi 2004-2007
Cobb Tuning AccessPORT / Subaru Impreza WRX 2008
Cometic Head Gasket / DSM / 85.5mm Bore / .051" Thickness
Cometic Head Gasket / DSM / 86mm Bore / .051" Thickness
Cometic Head Gasket / DSM / 87mm Bore / .051" Thickness
Cometic Head Gasket / Subaru EJ25 / 100mm Bore
Cometic Head Gasket / 420a / 88.5mm
Cosworth Mitsubishi 4G63 (EVOVII-VIII) High Performance Main Bearing Set
Crower Valve Spring & Retainer Set / EJ20
Dark Performance T4 Manifold / DSM
Defi Triple Meter Hood for New Age Impreza
Eagle Connecting Rods / Honda B16 (except JDM B16B)
Eagle Connecting Rods / Honda D16 & ZC
Eagle Connecting Rods / Honda B18C
Eagle Connecting Rods / 6 Bolt DSM
Eneos 0W50 Fully Synthetic Motor Oil
Eneos 5W30 Synthetic Blend Motor Oil
Eneos 5W40 Fully Synthetic Motor Oil
Exedy Stage 1 Organic Clutch Kit / STi
Exedy HD Twin Disc Clutch Kit / Evo
Ferrea Exhaust Valves / 1mm Over / EJ257 (Set of 8)
Ferrea Intake Valves / 1mm Over / EJ257
Exhaust Valve Stem Seal / DSM & Evo(Set of 8)
Fuel Injector Clinic 650cc Injectors / DSM
Fuel Injector Clinic 750cc Injectors / DSM
Fuel Injector Clinic 850cc Injectors / DSM
Fuel Injector Clinic 950cc Injectors / DSM
Fuel Injector Clinic 1050cc Injectors / DSM
Fuel Injector Clinic 1150cc Injectors / DSM
Fuel Injector Clinic 1600cc Injectors / DSM
Fuel Injector Clinic 750cc Injectors / Evo
Fuel Injector Clinic 850cc Injectors / Evo
Fuel Injector Clinic 950cc Injectors / Evo
Fuel Injector Clinic 1050cc Injectors / Evo
Fuel Injector Clinic 1150cc Injectors / Evo
Fuel Injector Clinic 900cc Injectors / SRT-4
Fuel Injector Clinic Complete Seal Kit for 4 Injectors 550cc-1150cc (Includes Viton Lower Seals)
Fidanza Aluminum Flywheel / Subaru Impreza 2.5L
Fidanza Aluminum Flywheel / Subaru WRX STi
Fidanza Aluminum Flywheel / 6 Bolt FWD DSM
Fidanza Aluminum Flywheel / 6 Bolt AWD DSM
Fidanza Aluminum Flywheel / 7 Bolt AWD DSM
Fidanza Aluminum Flywheel / 7 Bolt FWD DSM
Fidanza Aluminum Flywheel / Evo 8
Fidanza Replacement Friction Surface / DSM
Fidanza 4.3 Clutch Kit / Subaru 2.0L WRX
Fidanza 2.1 Clutch Kit / DSM
Fidanza 3.2 Clutch Kit / DSM
Fidanza 4.3 Clutch Kit / DSM
Fidanza 3.2 Clutch Kit / Evo 8 (5 Speed Only)
Fidanza 4.3 Clutch Kit / Evo 8 (5 Speed Only)
Fidanza Short Shifter / WRX
Fidanza Short Shifter / Evo
Fidanza Short Shifter / SRT-4
Fidanza Adjustable Cam Gears / Silver / B-Series Honda & Acura (Pair)
Fidanza Adjustable Cam Gear / Dodge SRT-4 (Clear / Pair)
Fidanza Adjustable Cam Gear / Dodge SRT-4 (Blue / Pair)
Forced Performance Exhaust Manifold Stud & Nut Kit / 6 Bolt
Forced Performance Exhaust Manifold Stud & Nut Kit / 7 Bolt
Fuelab Filter, In-Line Long Length AN -10 Inlet/Outlet (40 micron Stainless Steel element)
Gates Racing Timing Belt / 4g63
Greddy Timing Belt / WRX & STi
Hallman ES Manual Boost Controller / Black
Hallman Pro Manual Boost Controller / Black
Hawk Performance HPS Brake Pads / Front / 97-01 Impreza
Hawk Performance HPS Brake Pads / Rear / '02-'03 Subaru WRX
Invidia SS Downpipe / Open Bellmouth / WRX & STi
Invidia N1 Catback Exhaust System / WRX & STi
Invidia N1 Racing Catback Exhaust System / WRX & STi (No Resonator)
Invidia G200 Catback Exhaust System / WRX & STi
Invidia SS Downpipe / Evo
Invidia G200 Cat Back Exhaust System / Evo
Invidia N1 Catback Exhaust System / Evo
Invidia Turbo Outlet / Evo
Invidia SS Downpipe / Catted / Divorced Wastegate / WRX & STi
Invidia SS Downpipe / Non-Catted / Divorced Wastegate / WRX & STi
K&N Performance Gold Oil Filter / Subaru WRX & STi
K&N Performance Gold Oil Filter / 7 Bolt DSM & Evo
2.5" Aluminized Steel 90 Degree Bend
2.5" Aluminized Steel Combo Bend / 180 Degree + 45 Degree
2.5" Stainless Steel 105 Degree Bend
2.5" Stainless Steel 110 Degree Bend
3" Aluminized Steel 90 Degree Bend
3" Aluminized Steel Combo Bend / 180 Degree + 45 Degree
3" x 6" Braided Flex Section
Exhaust Hanger
Megan Racing 3" SS Test Pipe / Evo
Mishimoto Aluminum Radiator / 95-99 Mitsubishi Eclipse Turbo, Manual
Mishimoto Aluminum Radiator / 03-06 Mitsubishi Lancer Evolution, Manual
Mitsubishi OEM O2 Housing to Downpipe Gasket
Balance Shaft Elimination / Block Off Cap
Balance Shaft Elimination / "Stub" Shaft
Mitsubishi Balance Shaft Bearings
Mitsubishi Exhaust Manifold Gasket / DSM
Mobil 1 0w40 Synthetic Motor Oil
Mobil 1 10W30 Synthetic Motor Oil
Mobil 1 15w50 Synthetic Motor Oil
Mobil 1 15w50 Extended Performance Synthetic Motor Oil
Mobil 1 5w30 Synthetic Motor Oil
Mobil 1 Synthetic ATF
Mr. Gasket Fluidzap Pad
1.3 Bar Radiator Cap
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
