Old 07-12-2008   #1
mdost03
Sonic Champion!
Drives: VA STI
Quick Oil Catch-Can question
Alright, I think I know the answer to this, but just want to verify. Maybe the question is more towards Scheides since I am trying to mimick his setup almost from his EVO.
I bought this catch can and received it in yesterday:
Just wondering if I capped off the top filter port with a rubber vac cap if it would basically run like this one then (AKA Filterless):
The plan would be to cap off the top filter and then connect the valve cover breather and PCV lines together and route to the 1 port and then take the other one and hook it up to the vacuum line the PCV was hooked up to. Kracka vents would be put on both sides to make sure no boost enters the crankcase.
