Old 08-02-2008   #1
driftn1g
random shut offs
Just recently my wires where fried by the o2 dump, i wrapped them up and now SOMETIMES when i hit a bigger bump the car just shuts off, takes a minute to start back up.. what are these symptoms of??
thanks
alex.
Old 08-02-2008   #2
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: random shut offs
You probably need to replace the wires. There not getting a very solid connection and when you hit a bump it moves them just enough to not get the connection they need. I'm assuming these wires go to your alternator.
-1990 Mitsubishi Cyborg 4WD-
Old 08-03-2008   #3
driftn1g
no its the main harness of wires, it powers----the lights, fan, inside gadgets, ect..
Old 08-03-2008   #4
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
Even still the main clump of wires running up to the fuse box has the power wire to the alternator in it, or it would be the wires powering the entire fuse box, that powers just about everything in the car. So like he said the wires probably should be replaced.
Mwolf83 is offline   Reply With Quote
