Old 08-10-2008   #1
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Cheap parts come get them!
Ignore the dog hair! lol. If you want any parts just PM me or give me a call at 651 247 5990. My name is Andy.
1g o2 housing. One stripped stud.. $10
1g windshield washer resivour (fluid included!) $10
1g clutch line holder bracket $5
1g lower heat shield. cut for 2g o2 housing (HAVE UPPER SHIELD ALSO!) $5
2g crank pulley $20
1g SMIC $20
1g power steering/engine mount bracket $10
1g exhaust mani. no cracks! $15
2g o2 housing. both studs stripped.. $15
2g UICP with bov $5
1g power steering fluid resivour $15
1g good working o2 sensor $30
2g thermostat housing $20
1g power steering bracket with heat shield $10
1g power steering pump $30
1g stock fuel pump $20
2g stock intake box with filter $10
1g stock muffler $20
1g stock pressure plate. still has life left. $20
3.5" GM maf $30
-1990 Mitsubishi Cyborg 4WD-
Old 08-10-2008   #2
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: Cheap parts come get them!
So umm.. No body needs any parts?
Old 08-10-2008   #3
driftn1g
got any new motor mounts
Old 08-10-2008   #4
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I have a 2g driver side motor mount. But the rubber is torn. Would be good to fill or put in prothane
Old 08-10-2008   #5
I might take that o2 sensor off your hands. Are you available tomorrow evening at all?
Old 08-10-2008   #6
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Yeah if I work I will only work til 5. So anytime after that I'll be around. Just give me a call.
Old 08-11-2008   #7
ghost
Drives: 92 Talon TSI AWD
Send a message via MSN to ghost
I'll take the 3.5 maf, if you still got it.
-Ghost
ghost is offline   Reply With Quote
Old 08-11-2008   #8
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Sure do! I'll PM you with my info.
Old 08-11-2008   #9
curt_gendron
curt_gendron's Avatar
What ever parts you have left, you should bring to the swap meet at the All Mitsu Weekend Dyno Challenge on the 23rd. Great place so sell those small bits and pieces. But you probably already knew that.
later,
Curt
Minnesota 3/S
Old 08-11-2008   #10
johnson
johnson's Avatar
Drives: 90mitsu
hey do you have a clutch slave cylinder?
the one with the piston that pushes clutch fork?
Old 08-11-2008   #11
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
later,
Curt
Yeah I'm planning on bringing them. It's just gonna be dumb carrying all the parts in the trunk the hole time.. Maybe I will just have to give them away if they dont sell..?
Sorry I don't. I just replaced mine though cause the stocker finally gave up last week.
