Old 08-13-2008   #1
93gtpeater
Drives: cbr 1000rr repsol
awd to rwd
does anybody know how to convert awd tranny to rwd. i have seen it on youtube and i want to do it. does somebody make a special piece that goes in the tranny?
Old 08-13-2008   #2
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: awd to rwd
Not reccomended. If you want a RWD go buy one.
Amsoil Dealer
Old 08-13-2008   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: awd to rwd
Remove the front axles...
Originally Posted by shoutbox
Old 08-13-2008   #4
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Re: awd to rwd
Mighty max for the win. Or go by a starquest
Old 08-13-2008   #5
mike55112
mike55112's Avatar
Drives: 04 evo
Re: awd to rwd
Make up your mind. first you had awd, then converted to fwd and now you want to make your car rwd?
Old 08-13-2008   #6
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
Re: awd to rwd
OK this is how you do it.
First you need to get your center diff welded up so that when you pull out your front axles all the power will actually go through the transfer case and then to the rear of the car. You will need two extra CV's to get the half shaft and the knuckle from the passengers side to plug the holes in the tranny. Then you will also need the knuckles for the outer ends put into the hub to keep your wheel bearings tight. That is all, you have RWD, and since I actually did this for about a month last year, all I can say is that you can do sweet burnouts, but that's about all. The handling is complete sh*t (DSM needs front torque distribution to turn), braking is garbage (not sure why this is affected, maybe it needs engine load and tranny drag to slow down). So pretty much you have a car that sucks in all aspects except burning out. It cant even do a sweet RWD launch cuz the car doesnt have the same weight transfer as a RWD car. BOO
Mwolf83 is offline   Reply With Quote
Old 08-14-2008   #7
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: awd to rwd
Ya so like i said, not reccomended!!
Amsoil Dealer
Old 08-14-2008   #8
311evo
311evo's Avatar
Re: awd to rwd
rwd ftl.
Old 08-14-2008   #9
93gtpeater
Re: awd to rwd
thats gay it would be fun to do but not anymore. i made up my mind iam going back to awd next year. the reason is i go racing on uni and everybody knows now that iam fwd next year there wont know that i changed it back to awd
Old 08-14-2008   #10
johnson
johnson's Avatar
Drives: 90mitsu
Re: awd to rwd
dsm awd/fwd
colt/mirage fwd
starion/conquest rwd
how hard is that?
since its alll goin awd make a starion awd and youre set!
Old 08-14-2008   #11
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Re: awd to rwd
AWD starion FTW
Old 08-21-2008   #12
Re: awd to rwd
Skeet Skeet Racing FTL.
