Old 09-07-2008   #1
kittay
Lady dsmer
kittay's Avatar
Drives: 91 GSX, 91 TSi, 91 TSi
I hate dsms.. lol
I have the FPred on the black cherry. It's running the exact same times for 15psi as it is for 25 psi.
I'm thinking possibly a boost leak. But looking for other ideas.
Ran 13.6 all night long didn't matter the psi. Even bumped it up to almost 30 and ran the same.
For the last pass, the weld around the flange to the WG cracked, so there's an exhaust leak, but even with that, it still made a 13.7 pass. Going to get that re-welded of course. I'm thinking that has a huge factor, but before that it was doing the same thing with no exhaust leaks.
I'm getting absolutely no knock. And it's running about 10.5 AFR.
Car feels good, til I get on the track, then it's just disappointing. I was getting 1.813 60's so it just seems like my numbers are way down, esp the mph. The best mph I could pull out of it was 109.8
Just looking to get ideas. I'm heading out to fix the WG and check out boost leaks. So if you have an idea, please let me know
kittay is offline   Reply With Quote
Old 09-07-2008   #2
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: I hate dsms.. lol
^Work on your 60 fts and you should be golden. If you get your 60s closer to 1.3ish I would guess you'd get down to the 12s. When I tracked my car I was basically gettin the same shitty 60s and about the same times except my traps were like 101
If you don't have any boost leaks I'd just plane work on getting it outa the hole quicker....(that's what she said)
p.s. I'm dumb and idk anything
pics or gtfo
Old 09-07-2008   #3
kittay
Lady dsmer
kittay's Avatar
See I was getting the exact same times running a 2.2 60' last time out.
I really doubt I could pull a 1.3 60'. Next time out, I'm going to try pre-loading and try for a 1.6 60'.
There's something going on with the car.
Old 09-07-2008   #4
kittay
Lady dsmer
kittay's Avatar
Exhaust leak much??
Old 09-07-2008   #5
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
wow that sucks!!!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 09-07-2008   #6
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Holy shit! Did you buy that brand new?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 09-07-2008   #7
mdost03
Sonic Champion!
Drives: VA STI
Ouch, yeah that will definitely affect your spoolup time.
Old 09-07-2008   #8
Get that thing on the dyno, see what's up.
Old 09-07-2008   #9
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
1.8 is a respectable 60ft, 1.3 is very unrealistic for a DSM. I don't think it would be possible.
Your MPH seems fast for mid 13s. When I used to run my pretty much stock 14b powa'd AWD i was running 13 flats at 103mph. I would fix that WG and do a boost leak test. Then work on your shifting skillz.
Old 09-07-2008   #10
kittay
Lady dsmer
kittay's Avatar
No AWD dyno around here and we had made it ourselves. The weld hadn't penetrated all the way, but it had broken off around the weld.
Old 09-07-2008   #11
+1. I don't think this is possible.
Old 09-07-2008   #12
311evo
311evo's Avatar
i wonder what brent rau's 60ft is? :-P
Old 09-07-2008   #13
you are dumb.
Old 09-07-2008   #14
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Quicker than yours
Old 09-07-2008   #15
311evo
311evo's Avatar
Quicker than yours
i beg to differ!! oh wait..
Old 09-07-2008   #16
Yup; what he said.
Do a boost leak test and go from there. Lean it out a bit, 10.5 AFR seems rather rich.
Old 09-07-2008   #17
I have a time slip with a 1.28 60' on it, unfortunately it was by Curt Brown in the other lane.
That WG flange wasn't welded all the way around, so it was leaking the whole time. You are going to have to grind off the powder coating (all of it near the weld) and reweld the pipe to the flange all the way around.
You also need to work on your shifting, I ran a 13.6 @ 99mph. My 60' was pretty similar, it was a mid 1.7. A boost leak test is definitely in order after you get that fixed.
Old 09-08-2008   #18
kittay
Lady dsmer
kittay's Avatar
It was welded all the way around, it was just welded on the inside.
It is now all welded back up and welded inside and out. Car runs good and pulls hard now.
Hard to shift a car with a crap tranny I have to shift to second at 6500 to get it to maybe go in. lol.
Old 09-08-2008   #19
Get your leaks fixed and your problems will be solved. I was trapping 124-125mph with my FP Red on a decent tune and granny shifting it. I ran a 11.9 at 118 missing fourth gear completely.
Old 09-08-2008   #20
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Exhaust leak much??
Is that a bad thing?
