Old 09-29-2008   #1
slowboy101
slowboy101's Avatar
Drives: 91' Eagle Talon TSI
FMIC question
if I get a FMIC do I have to get a new radiator and fan or can I use the stock one?
slowboy101 is offline   Reply With Quote
Old 09-29-2008   #2
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: FMIC question
You can use the stock fans and radiator, they don't have anything to do with a front mount. It is tough running the turbo to inlet on a front mount on 1g's but it does fit.
Old 09-29-2008   #3
slowboy101
slowboy101's Avatar
Re: FMIC question
alot of dsm gods I know were saying i HAVE to get a slim fan
Old 09-29-2008   #4
Constant_Project21
Drives: E36
Re: FMIC question
You don't HAVE to. It makes it way easier, but I made mine work on my Laser. Then again we did a lot of custom fab, and I wanted to keep my power steering and a/c so I did a different routing on my turbo to inlet.
Old 09-29-2008   #5
Re: FMIC question
Stock radiator is fine, but you may need to get some slim fans.
Old 09-29-2008   #6
Re: FMIC question
If the stock one fits, keep it. Otherwise, two 10" or 12" push fans mounted inbetween the FMIC and the radiator are always a nice solution. Last thing you want is to overheat your car.
Old 09-29-2008   #7
Re: FMIC question
Also, I had a Flex-A-Lite FAL dual fan setup on my 2G that was freaking awesome. It mounted on the engine side, but man it did a good job.
Old 09-29-2008   #8
slowboy101
slowboy101's Avatar
Re: FMIC question
K thanks guys
Old 09-29-2008   #9
Re: FMIC question
I was using the two stock fans with my FMIC until I went to an external wastegate, then I had to remove the AC fan and just recently installed a pusher on that side.
Old 10-02-2008   #10
slowboy101
slowboy101's Avatar
Re: FMIC question
k thanks alot man
Old 10-02-2008   #11
Re: FMIC question
It depends on what turbo you are running, but you will likely have to get a slim line for the one on the driver's side. You can usually keep the pass. side one stock.
Old 10-02-2008   #12
green hornet
Re: FMIC question
i got a visteon alum rad, from a guy on here that had a 12'' slim fan on it, and i just recently put a huge front mount on, and i didnt even notice a change in temp, alum rad's are the shit!!
Old 10-02-2008   #13
Project2G
Semper Fidelis
Project2G's Avatar
Drives: 1997 Eclipse GST
Re: FMIC question
I bought this and it turned out great.
http://cgi.ebay.com/ebaymotors/ws/eB...m=230282577535
Old 10-18-2008   #14
lucasoil4u
Drives: talon tsi evo 3 25psi
Re: FMIC question
i got fmic and all i needed was a slim fan to clear the piping.
lucasoil4u is offline   Reply With Quote
