Old 09-29-2008   #1
Base Timing Problem
When I tried to set my base timing awhile back I had a problem. The timing mark was jumping all over the place. I have set the base timing before on these cars many times, and it normally sits still in one spot. My problem is the timing mark moves very erratically.
*Grounded with a jumper wire to the battery
*Timing light hooked to #1 plug wire
Any one have ideas? Bad CAS?
Old 09-29-2008   #2
blackrosenova400
blackrosenova400's Avatar
Re: Base Timing Problem
Yeah I notice when I set my timing, mine is somewhat stable, but sometimes it jumps. I cant remomber if it jumps advanced or retarded though. I wonder if mine is going bad.
Old 09-29-2008   #3
Maybe the pulley is starting to separate, a bad wire/connection when grounding the plug out?
Old 09-29-2008   #4
If you rev it up a little bit, it might get more stable. With the timing connector grounded, it should stay locked at 5 degrees, regardless of RPM.
Old 09-29-2008   #5
Mine bounces around a little bit, but still easy enough to adjust base timing to.
Old 09-29-2008   #6
Hmm, it just seemed more erratic than it ever has before, I'm just assuming some 16 year old part was dying.
Old 09-29-2008   #7
x-pride
x-pride's Avatar
Mine jumps all over the place too when the idle is at 500 RPM. If I raise the RPM to 900 the base timing stays at 5. What is your base idle?
Old 09-30-2008   #8
Ha, well I honestly dont remember. I've fucked with the BISS screw a lot and my ISC hates life (aka the grim reaper took it), it's been three weeks since I've driven the car. I wanna say just shy of 1000, without balance shafts and poly mounts it rattles the interior less at a higher RPM.
Now that I've said that, for setting the BISS Screw idle adjustment I thought you only had to ground the same plug that you use to set timing. Is that the only thing needed, as I've heard mumbling about the diagnostic port...
Old 09-30-2008   #9
Spyderturbo007
Spyderturbo007's Avatar
Albatross Overload (Yeti 4) Champion!
Drives: 1997 Eclipse Spyder GS-T
You also have to ground pin #10 on the diagnostic plug assuming it's a 1g.
On a side note, I don't see anyone's vehicle information in their profile. Is that normal, or am I missing something? I see that mine comes up under my username, but I don't see anyone elses'.
Spyderturbo007 is offline   Reply With Quote
