Old 10-03-2008   #1
Lean at Idle
My AEM o2 says normaly "---" which is max lean at idle, sometimes its between 18:1 and like 15:1. While cruising, the car sits at like 14.7 as it should.
Any ideas?
Old 10-03-2008   #2
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Lean at Idle
Mine does the same thing. Where is your sensor placed in your exhaust system? How far down? Mine is where the second o2 us and I am thinking of moving it up farther but you dont think that should matter since when they dyno a car its at the very back tailpipe.
Amsoil Dealer
Old 10-03-2008   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: Lean at Idle
Wouldn't it make sense to have the car idle lean? Cars usually dont use up that much fuel just idling.
-1990 Mitsubishi Cyborg 4WD-
Old 10-03-2008   #4
Re: Lean at Idle
I thought it'd be at 14.7...
My sensor is 36" away from the turbo outlet, per the AEM instructions, which on my 1g places it just behind the axel and between the crossmember. Perfect
Old 10-03-2008   #5
dsm9sec
Drives: ... More than you can afford, pal
Re: Lean at Idle
Have you gotten your car tuned prior to installing the WB?
Better yet, are you on a stock ECU?
dsm9sec is offline   Reply With Quote
Old 10-03-2008   #6
Re: Lean at Idle
yeah, stock ecu, pretty much stock everything else. Has a stock set zero'd out MAFT and stock 450s. Aeromotive AFPR and walbro 255hp. stock 14b also. stock 6 bolt kinda.
Old 10-03-2008   #7
dsm9sec
Re: Lean at Idle
Then I probably wouldn't worry about it. The stock ECU adjusts fuel trims as it sees necessary.
Old 10-03-2008   #8
Re: Lean at Idle
Mine does the same thing, and it's not right. In closed loop, your a/f should hover around 14.7, that's where it's supposed to be. Mine goes lean and the idle drops to 900rpm and it stumbles. I haven't had time to mess with it, it might be the removed honeycombs on my maf, I'll find out soon enough.
Old 10-03-2008   #9
Re: Lean at Idle
Sleepy, it sounds like your WB is probably getting too cold and not giving a reading any more. Mine used to do that at idle sometimes too. I was actually too rich causing the sensor too cool too much at idle. I can really see the problem with it being that far away from the engine, that is a long ways away.
Old 10-03-2008   #10
dsm9sec
Re: Lean at Idle
My WB is right where it sounds like Kevin put his. 1" behind the half shaft @ the center of the motor and mine didn't cool. I thought they were self-heated?
One thing I do know for sure is DO NOT put it right where the turbo outlet is if it's a street car. Mine burned up in 2 months @ that spot.
Old 10-03-2008   #11
Re: Lean at Idle
Yep, had that same thing. Put it in the stockish location and went through three sensors in 600 miles. I've been on this new one all year around 1500 miles.
Old 10-07-2008   #12
Spyderturbo007
Spyderturbo007's Avatar
Albatross Overload (Yeti 4) Champion!
Drives: 1997 Eclipse Spyder GS-T
Re: Lean at Idle
Mine was doing the same thing and it turned out to be an exhaust leak. If you were running that lean, you would be maxing out the FT's and ending up with a Fuel Trim Malfunction (Bank 1) CEL, so it sounds like your exhaust leak is somewhere between the front O2 and the WBO2. Mine was a blown O2 housing to DP gasket.
-Nathan
Spyderturbo007 is offline   Reply With Quote
Old 10-07-2008   #13
Re: Lean at Idle
1Gs don't throw fuel trim errors, thats an OBD2 function.
Old 10-07-2008   #14
Spyderturbo007
Re: Lean at Idle
I didn't realize that it was a 1g. Anywhere around here where you can find what vehicle people have? I'm new, so I don't know anyone and can't seem to find anything in anyone's profile.
-Nathan
