Old 10-03-2008   #1
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
A head scratcher. I need help fast.
Please read everything before offering advice. Ive checked a lot of stuff, and I don't feel like referring to back to the first post 80 times. Thank you in advance for any help
Problem Vehicle: 1998 Plymouth Neon
Problem symptoms: Solenoid clicks, starter motor does nothing
Problem History: Came out of the blue with the old starter, starter was replaced, started 4 times, problem came out of the blue again
Items Checked: (all ohm readings are actual, no multiplier)
-Battery checked out at almost 800 CA and is at 12.56v
-Power post at solenoid to ground reads 12.56v
-Power wire to solenoid from battery, tested out at 2 ohms resistance
-Starter housing to negative battery post tested out at -2 ohms resistance
-Starter was manually jumped via a direct jumper to positive post, solenoid just clicked, no starter motor action
-Neutral safety switch was checked
-Fuses and Relays all checked out
Items Not Checked:
-Fusible link to alternator (this shouldn't matter for actual start up)
-Starter housing to ground to see if voltage occurs indicating a short
Potential Problems Considered:
-Seized TC, the car does roll however, in gear and neutral
-Seized engine, Seems unlikely, no over heating and no odd behavior prior to shut down
-Faulty starter
