Old 10-05-2008   #1
Turbo oil feed pressure restrictor question
I want to find a product that will limit the oil pressure to my turbo. I have heard that conquest create too much pressure after balance shaft removal and a regular garrett turbo (which I have, but not run yet) will die a quick death.
Anyone know of a good adjustable regulator or backpressure relief valve with a gauge on it so I know how much I'm affecting it?
Old 10-05-2008   #2
Re: Turbo oil feed pressure restrictor question
I don't know of any restrictor with a gauge but i know FP sells one and so does slowboy.
Old 10-05-2008   #3
best bet is to put a T in your feed oil line where the line meets the turbo, and run that T to a pressure guage. On the other side of the T try installing various restriction orifices until you see the pressure you want. Once you see a pressure you are comfortable with, remove the T and the guage.
You can buy those restrictor orifices at just about any online turbo shop.
Old 10-05-2008   #4
FP Link
The above way would work too, but the fp just seems like a simpler/easier solution.
Old 10-05-2008   #5
Thanks fellas!
Old 10-06-2008   #6
Local buddy of mine runs a small business selling oil feedlines to the Honda crowd. He sells little restrictors as well. Here's a link to his. You could probably find something similar to it for cheaper on McMaster's site.
http://stealthmodeperformance.com/oil-res.shtml
If you're in town, you could probably just drive to his place in Farmington and just pick it up from him.
Old 10-06-2008   #7
mdost03
Sonic Champion!
Drives: VA STI
What kind of turbo is it for?
Old 10-06-2008   #8
an sc61 regular bearing.
Old 10-06-2008   #9
on a 2.6? sick.
Old 10-07-2008   #10
Hopefully.
