Old 10-05-2008   #1
Brent Rau
Frightens Puppies with a Flick of the Ankle
6 bolt blocks/heads
I need 2 1g blocks, and 2 1g heads.
Brent Rau is offline   Reply With Quote
Old 10-05-2008   #2
93gtpeater
Drives: cbr 1000rr repsol
Re: 6 bolt blocks/heads
i got a 1g head that needs valves and one that doesnt need anything. and a whole motor that runs for $450 or best offer.
Old 10-05-2008   #3
dsm9sec
Drives: ... More than you can afford, pal
I have a bare 6 bolt block w/ squirters $50.
dsm9sec is offline   Reply With Quote
Old 10-05-2008   #4
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
I have a running 6 bolt long block. Untouched with ~140k on it. Leak down showed some ring loss. Only a little valve loss. Make an offer.
Also have 6 bolt short block. .020 over with 2G pistons. Crank is almost certainly out of spec. Was running, but knocking when pulled. Make an offer. (probably not as virgin as you would like...)
Old 10-05-2008   #5
chaunceyracer
I have three blocks and one head available. PM sent.
chaunceyracer is offline   Reply With Quote
