Old 01-20-2009   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
worth keeping a 7 bolt?
I have a 7 bolt N/A block and I am wondering if it is worth keeping around or if I should get rid of it.
I know the early 2g 7 bolts have crank walk problems but I don't know if the 1g blocks did.
Plus it is N/A so no oil squirters
There are a lot of 7 bolt 4g64 cranks at the junk yard. Would it be worth thinking about doing a 2.3 block?
or is this really not even worth my time?
Old 01-20-2009   #2
Re: worth keeping a 7 bolt?
Is this a 4g63 or 4g64 block you're talking about? a 4g64 would be a 2.4 not a 2.3.
Old 01-20-2009   #3
I understood that he was going to use a 7 bolt 4g64 crank in a 4g63 block.
Old 01-22-2009   #4
Andrew7dg
Andrew7dg's Avatar
correct. the 7 bolt 4g64 blocks are everywhere in the junk yard and I have a 1g 7 bolt 4g63 block out of a n/a block.
Or I could keep it a 2.0L because the cranks are the same from the turbo motors. All I would have to do is change pistons. Actually I have a set of rods and 8.5 pistons out of a 2g motor. Still need the oil squirters though.
I ask this because after reading jacks transmissions i found this on there website
http://www.jackstransmissions.com/st...3893721b961a60
"The only fear people have of the 7-bolt is crank walk. We believe the 7-bolt is a superior engine to the 6 as the 7 has a far stronger crank, better compression ratio, nice strong girdle, helix angle in oil pump (for a quieter engine) and lighter rotating assembly. Buying a 7-bolt from us will eliminate the crank walk problem, so why not go with the better engine."
However I don't know how much difference there is between a 2g 7bolt block and a 1g 7bolt block
Any opinions on this?
Old 01-22-2009   #5
The 7-bolt crank is not better than the 6-bolt.
Old 01-22-2009   #6
I remember Artie Effem saying otherwise. I think it had to do with the radius on the crank journal edges.
Old 01-23-2009   #7
Yeah, but I think they came up with that it's made of a slightly softer material.
Old 01-23-2009   #8
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Do you know when you are going to use it? Do you have a plan to use it? If not ditch it, being a pack rat takes up way too much space.
Is it the new style block that has the thrust washers separate from the center main bearing? If it is, it's worth keeping, if it has the 6 bolt style center main bearing, you're just asking for crank walk if you use it.
Old 01-23-2009   #9
I have beat the hell out of the evo III 7bolt for over 30k so far my self before that it was in a rally car. It is just fine 7bolt still even with the twin plate for almost a full year now. The evo III engine does not have squiters in them
Old 01-23-2009   #10
brando
Drives: gutlass
oil sqirters arent really a necessity. its no lie that 7 bolts can produce numbers easier than 6 bolts. i do belive that it is just because of the pistons though. we will see. my 6 bolt is getting 2g pistons and my buddy is gonna built his 7 bolt so we will seere which one works out better
Old 01-24-2009   #11
jrohner
jrohner's Avatar
Might as well go with the 2.4 block and all.
Old 01-26-2009   #12
Andrew7dg
Andrew7dg's Avatar
Ok I have decided I don't have a car to put the 7 bolt in and it is the old style 7 bolt so it is not worth keeping around. I will be keeping the head and posting that forsale (7bolt 1g head)
Like stated before it is not worth the clutter around the place
and might as well go 2.4L
