Old 02-23-2009   #1
viridionplague
viridionplague's project
so i think its about time i posted some shit up here. ive got a 1992 talon tsi here. cant says its a bad car but it has its "quirks" eventualy they will be fixed but for now, ill keep it at one step at a time.
recently i bought the punishment racing FMIC kit. cost at 410 to my door so its not bad, i see the same kit on ebay at 369 with 31 bucks shipping.
i cant says its a bad kit but it lacks a few things some of the nicer kits would have. first there are no instructions at all!! the supports are kind of thin and flex under the weight of the core. and the j-pipe dosent have a nipple. also the supports were not drilled out large enough for the bolts provided so i had to do that myself.
anyways, i got most the way done, the core is mounted, just need to hack up a pipe to fit my maft and get or the pipes conneted
here i got the ever so wonderfull sawzall going and cut out the rad supports. this is the first hole, i took the pic right away, its mostly just bent out of the way and hammered down the rough spots
pic of the car after flexing the radiator out of the way in order to avoid punching it with the sawzall.
core installed
a little uneven but i left off here for the night.
anyways i should have this finished up tomorrow and ready for testing. woot. ill also have more pics up of the whole car, ive got a long way to go with it so ill try to keep this updated as it stays relevant.
feel free to ask questions or post any advice
Old 02-23-2009   #2
Re: viridionplague's project
lookin good..keep it up!
-A. Swift
Old 02-23-2009   #3
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
That'll look real nice. I forgot you even had a DSM :P
Old 02-23-2009   #4
post up more pics of the car!
Old 02-23-2009   #5
Nice. Hope those couplers work out for you. Apparently you aren't all that far from me. Gimme a shout if you ever need a hand.
Old 02-23-2009   #6
Cool man! What else is there done to this ride o yours?
Old 02-24-2009   #7
viridionplague
i havent done alot to it because when i got it i was involved with a bad shop and things went south in a hurry.
it has a turbo back 3" exhaust, maft, shep stage 3 rebuild, and a fidanza 3.2 clutch.
as well as the punishment racing fmic that i finished up today and am now working out bugs.
all have some more pics of the install in a few minutes along with my final thoughts on the fmic kit.
Old 02-24-2009   #8
That's a nice looking FMIC. I like it!
Old 02-24-2009   #9
viridionplague
i forgot to mention ive got a set of 880's around as well as a fuel pump i need to throw in
yea the kit looks realy nice but it was kind of a pain to deal with, definatly not what i would call a bolt on kit
Old 02-24-2009   #10
looks nice
Old 02-24-2009   #11
viridionplague
ok so here are a bunch of pictures cause everyone likes pictures, i didnt get any of the whole car as its coated in salt and it got dark out though.
as for the kit, i had to cut alot more than the standard radiator support spots in order to get this thing to work. i had to cut all but 1 pipe i got in the kit to make it fit right, and it wasnt because i used the wrong stuff in the wrong spots, i test fitted everything in just about every way possible. i probably got a good foot of aluminum pipe chunks.
as well as having to drill out the supports to get the supplied bolts though.
over all though for the price of 410 shipped it still isnt super bad as it saves to time of welding the j-pipe and the throttle body elbow.
as you can see in the pics ive got my maft setup right on the throttle body elbow and the bov right before that. it works out pretty well.
now for the bad though, the j-pipe dosent have a nipple yet, so untill i go get one welded in had to splice into the bov line.
i dont exactly know what the second nipple on the bov is for as the kit comes with no instructions at all.
due to haveing to cut all the pipes most of them done have the ribs to hold the couplers on.
the first time out with the car, the wastegate actuater was not hooked up properly, luckily i preped for this by looking at the boost guage the whole time and i shifter at about 13 psi. after that the car slowly builds boost and dosent realy want to go past 7 psi.
and for all those who laughed at me before because part of the reason i bought the fmic kit was to solve a fuel cut issue, well i dont have fuel cut anymore.
anywas, as far as i can tell everything is hooked up and bolted down correctly, i dont know what the second nip on the bov is for so i just blocked it off after trying a few things to fix the boosting problem to no avail.
if anyone has any suggestions on what this might be, any help is appreciated
Old 02-24-2009   #12
Cut alot out? ya..now imagine doing it to fit 3-3.5" piping!
It looks to me like the other nipple on the BOV is another spot to get your vac signal from..ones above the diaphram, the other is below. works well for EBC's i believe. you should be fine with it as is.
adding a FMIC won't fix any fuel cut issues..air to the motor is air to the motor. However if you moved the maft any bit, or have no more boost leaks cuz it is all properly installed, that could help
-A. Swift
Old 02-24-2009   #13
viridionplague
i actualy did not have any boost leaks on the old setup, im pretty sure the only thing that fixed it was moving the maft from a pull through to a blow through setup fixed my specific problem
Old 02-24-2009   #14
viridionplague
ok so i was wrong fuel cut has not been fixed, turn out i just blew a hose off, but it still went to redline.
so i got evertyhing back on she boosts fine, but im still getting fuel cut at 4500 rpm, no boost leaks of any kind.
ive been trying to figure this out for a while now, could it just be a bad map sensor?
or do i need to replace the whole unit
Old 02-24-2009   #15
mdost03
Sonic Champion!
Drives: VA STI
The lower BOV nipple is for an all-boost source to release boost pressure faster than just the vac nipple on the top. Leave it open if you aren't using it.
I would just get an NPT nipple from Home Depot and drill a hole in your j-pipe and screw the nipple in by force. That is what I, and a few people I know, have done to get a boost source. If you are worried about leaks, maybe put a little jb weld on it to seal it up better.
Old 02-24-2009   #16
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
1g's don't have map sensors. Did you spray soapy water on everything and pressurize the system?
-1990 Mitsubishi Cyborg 4WD-
Old 02-24-2009   #17
viridionplague
ok so before i decided go go replace my gm 3bar map sensor i pulled the ecu, on a good note, all caps are good, and its an eprom, on a bad note, one of the memery chips burst.
anyone got a 1g ecu, suck
Old 02-24-2009   #18
What chip is burnt out on it?
I have a spare 1G EPROM ECU. I think it has a Keydiver chip in it though, so you might need to swap in your stock chip. I'm not really looking to sell it because I like to have a backup, but if the one you have isn't in horrible shape I'd be willing to trade you for your bad one plus say $100 cash?
Old 02-24-2009   #19
viridionplague
pm sent halon
Old 02-24-2009   #20
The chip that blew up in your ECU was one of the ones used to drive your ISC. It shouldn't affect anything else other then that, unless it's "guts" damaged some other circuits (specifically IC104 which is part of your MAF circuit)
Whether you buy a new ECU, or get this one repaired, you need to either replace your ISC with a good one, or leave it unplugged, or else your next ECU will burn up that same chip instantly.
