Old 02-23-2009   #1
ghost
Drives: 92 Talon TSI AWD
Send a message via MSN to ghost
looking for some parts
1g front driver side axle (a good one)
v-band wastegate
v-band o2 housing to a 3" downpipe
1g awd scatter shield
-Ghost
ghost is offline   Reply With Quote
Old 02-24-2009   #2
v8klla
v8klla's Avatar
Re: looking for some parts
We can build you an O2 housing around the new Tial 38mm vband wastegate, I'll make it worth your while as we would like to make a jig and reproduce these things anyways, let me know if this interests you!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 02-24-2009   #3
ghost
That sounds great because I've been looking all over for something like that and nobody seems to have it. I did wanted the v-band 38mm wastegate too. Here's my setup though, I got t4 DNP ex-manifold bolt up to a GT4088 turbo and my downpipe is a 3" Thermal. All I'm missing is the wastegate and that o2 housing area that will connect the two. I still have my motor out of the car and still working on some things around the engine bay, but when my car is ready I wouldn't mind towing my car up to you guys and it let it be tested on. So was this something you were looking for or not?
-Ghost
Old 02-24-2009   #4
v8klla
v8klla's Avatar
I'm a bit confused sir. The DNP has a 44mm wastegate flange correct? The new MVS is a different flange unfortunately. Are you looking to have the dump rerouted into the O2 housing?
P: 763-545-3800
Old 02-24-2009   #5
ghost
I just thought maybe the new v-band 38mm will fit. Either way I'm still looking for that o2 housing area that is 3" v-band from the turbo to my 3" downpipe.
-Ghost
Old 02-24-2009   #6
v8klla
v8klla's Avatar
Well we can definitely make that for you sir. We would need either the car or your manifold/turbo setup to bolt up to our jig though. Let me know!
P: 763-545-3800
Old 02-24-2009   #7
ghost
I'll keep looking but if I cant find anything, I'll come to you guys. Thanks though.
-Ghost
