Old 02-25-2009   #1
slowboy101
slowboy101's Avatar
Drives: 91' Eagle Talon TSI
Is my boost gage shot?
How do I test my boost gage? It says I'm pushin 20 PSI but I dont think it is!
slowboy101 is offline   Reply With Quote
Old 02-25-2009   #2
Re: Is my boost gage shot?
What makes you feel its wrong?
Old 02-25-2009   #3
311evo
311evo's Avatar
whats a "gage?"
how do you know you pushing 20 psi, if you think your gauge is broken?
Old 02-25-2009   #4
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
What does you're needle read when the car is off?
-1990 Mitsubishi Cyborg 4WD-
Old 02-25-2009   #5
Very weird thread, I don't get how you think its making more or less boost than what it says. I think I'd try to take off the boost line, use a compressor with a regulator, blow air into said line and see if it reads the same as what the regulator is set at. I don't know if that'd actually work but I think it could be close?
Old 02-25-2009   #6
slowboy101
slowboy101's Avatar
Well I was in my buddies 1g and he's pushin 10psi and it felt like the pull was way stronger
Old 02-25-2009   #7
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
It all depends on mods and/or condition of engine. Once again.. what is the boost gauge reading when the car is off?
Old 02-25-2009   #8
Maybe you buddies gauge is off.
Old 02-25-2009   #9
slowboy101
slowboy101's Avatar
when the car is off the gauge reads just below 0
Old 02-26-2009   #10
cause your car is slow! j/k mike..he probably has a bigger turbo..DUH!
