Old 03-03-2009   #1
4seasons69
4seasons69's Avatar
need help with boost leaks asap
ok I am very frustrated right now it doesn't seem to matter what I do I can't get rid of my boost leaks. I know how to prep gasket surfaces and install gaskets and torque bolts properly but no matter how well I do it my bov and throttle body just keep leaking. as well as a couple other little places. should I try rtv? I'm completely lost right now so any help would be great and or if any of you who have more experience with fixing boost leaks would be willing to help me sometime (at my place or yours) would be absolutely wonderfull as well. sorry for rambling on any help is greatly appreciated
Old 03-03-2009   #2
Re: need help with boost leaks asap
use RTV, but sparingly. Use as little as possible to get the pieces to seal. A VERY very thin amount on both sides of a gasket will do wonders. Give it some time to set up.
Old 03-03-2009   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
^^^ +1
-1990 Mitsubishi Cyborg 4WD-
Old 03-03-2009   #4
4seasons69
4seasons69's Avatar
from past experiences using rtv on gaskets more often than not makes them squish out. I'll just try making the gaskets with rtv and see how that works
Old 03-03-2009   #5
Often BOV and throttle body elbow flanges are warped and need to be run on a belt sander to make them flat. I usually use only RTV and no gaskets on things like bovs and throttle bodies that don't want to seal. I have had better luck with just RTV vs gasket + RTV, but every case is different.
Old 03-03-2009   #6
4seasons69
4seasons69's Avatar
the thing with the tb is that when I did the head I sanded that very well (not with a belt sander) with a perfectly flat sanding block and even removed the studs from the intake mani and sanded that good and checked them with a straight edge and there wasn't any noticeable gaps
but obviously I didn't do a good enough job
Old 03-04-2009   #7
brando
Drives: gutlass
use black rtv only!!!! its the only kind worth a damn. or you can try aviaton sealant
Old 03-06-2009   #8
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
I'm having a weird throttle body leak as well. I can't pinpoint it, i think its coming from the back/underside of the TB. Also getting one from the back/underside of the turbo?? wtf. Can't directly see either of them.
Style's automotive engineer
Old 03-06-2009   #9
4seasons69
4seasons69's Avatar
just use rtv on the throttle body as for the turbo I dunno what to do about that one. I just rtv'd my throttle body and bov yesterday so I'm gona do a boost leak test to see if that took care of my leaks
Old 03-06-2009   #10
s1ngletracker
Drives: A BMW
eh, i'm not a huge fan of doing that. The gaskets should get a good seal without sealant. I'll probably just get new gaskets.
Old 03-06-2009   #11
4seasons69
4seasons69's Avatar
I preped the gasket surfaces very well when I had my head rebuilt and it still leaked. just save your self the time and rtv it the first time so you don't have to redo it again like I did
Old 03-06-2009   #12
s1ngletracker
Drives: A BMW
did you use new gaskets? The right gaskets? are you sure the surfaces were flat? bolts torqued down properly and evenly? If all those things are done right, it shouldn't leak.
Old 03-06-2009   #13
4seasons69
4seasons69's Avatar
yes, yes, yes, and yes. I didn't have the surfaces machined but my teacher has a perfectly flat sanding block that we sanded everything very well with and my teacher inspected everything so I know it was good. it still leaked pretty bad too
Old 03-06-2009   #14
4seasons69
4seasons69's Avatar
I suppose I could have the gasket surfaces machined to be perfectly flat but I don't see the point in paying for that when if used properly rtv will work just as good or better
