Old 04-01-2009   #1
TsiEagleTalon92
TsiEagleTalon92's Avatar
Drives: 2022 Hyundai Palisade
A/C Compressor
I am looking for a broken or working one VERY cheap. I need one so I can cut the bracket out for my axle. Or any ideas on what people have done instead only as long as it is good.
Old 04-02-2009   #2
Re: A/C Compressor
I have a few of the spacers I cut out from the brackets
Old 04-02-2009   #3
TsiEagleTalon92
Re: A/C Compressor
That would be exactly what I need. What about the half shaft or bearing that I need as well? The bearing on mine is shot from only being held in by one bolt and bad spacing.
Old 04-02-2009   #4
acidrumz
Re: A/C Compressor
that extra space from a/c bracket removal, just add some washers and be done. also you would want to add a lock washer behind that nut.
Old 04-02-2009   #5
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: A/C Compressor
Get one of the brackets from TKRperformance. You can do washers, but then any time you need to pull the axle you have to keep track of them. If you use a cut part of the factory bracket you can just use the axle bolt hole and the one above it, which will keep it in place when you have to pull the axle.
If for some reason you actually need a compressor and not just the bracket I should have one around. No brackets in my garage though.
Old 04-03-2009   #6
TsiEagleTalon92
Re: A/C Compressor
I used washers which I hated. I have no need for a compressor thank. Full A/C removal here. I didn't know at the time if the bracket was apart of the compressor or not.
Where would I find the bearing for the axle I need replacing? Dealer maybe? I tried oreily but they sucked.
