Old 04-07-2009   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Alot of 1g & 2g Parts For Sale
DSM Parts
Need to sell these parts ASAP so I do not have to bring them with me when I move.
Send me any reasonable offers!
1g grey leather seats with matching door panels
1g dark grey door panels driver and passenger
1g center consol carpet
1g auto transmission transfer case
1g intercooler
1g rear passenger tail light
1g stock floor mats
2g fwd driver axle
2g awd passenger front axle
2g radiator
2g talon passenger tail light
6 bolt 2.0 block
6 bolt 2.4 block
Here are more parts for sale. Just send me an offer.
1g---
6 bolt timing belt >500 miles
plug wire cover
harmonic balancer
dip stick & tube
front seal housing
tensioner arm and motor mount
timing pulleys
Lower crank timing belt sprocket
1g Non Turbo Throttle body
plug wires
transistor
o2 housing gasket
exhaust mani gasket
fuel rail
FPR fuel pressure regulator
manual 91+ shifter assembly
driver mirror
throttle position sensor
awd brand new rear rotors
valve cover bolts
gauge cluster with 112K miles
flip up headlight bulbs brand new
delta gate 38mm wastegate needs seal
90 awd 4 spyder center differential
flip up headlight assembly with bulb
radio trim
cup holder
flip up headlight motor
flip up headlight trim
stock boost tubing
2g---
center vent with switches
radiator hose
97+ turbo ECU
Plug wire cover
stock fuel line from filter to rail
harmonic balancer
stock fuel pump
maf sensor extension wire
shift fork
front seal housing
timing pulleys
Random brake pads with very low miles
transistor
turbo water pipes
o2 housing gasket
manual shifter assembly
speed sensor
stock throttle body with lower sensor
gauge cluster trim
Infinity stock amp
thermostat housing
starter
dual piston front calipers
aftermarket rear muffler
High flow magnaflow 3" cat
Amsoil Dealer
