Old 04-09-2009   #1
2g Monson
2g Monson's Avatar
Drives: 1995 Eclipse GST
What should I spend my money on now?
Well its spring and I'm trying to decide on what to buy for my car. I want some more power but Im confused what to do. I have a 95 GST with: 16g turbo, fmic, 255 fuel pump, 550 injectors, Neo AFC, and running 17psi. Im pondering some bigger injectors and an intake manifold, or cams and came gears, or DSM link. Is it preferred to use a PC for that or does a MAC work good too? Any advise would be great
2g Monson is offline   Reply With Quote
Old 04-09-2009   #2
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: What should I spend my money on now?
I don't think the intake mani or the cam gears are necessary, cams and ECM link is what I would be buying if I had the money.
Old 04-09-2009   #3
sell the neo and get ecmlink v3. it can run on a mac also. get a set of 272 cams for it,bigger injectors and tune on e85 that would be good for a fun street car
Old 04-09-2009   #4
viridionplague
exhaust? wideband 02 sensor. dsmlink
Old 04-09-2009   #5
dsmlink ($400-$500 assuming you already have an eprom ecu since it's 1995), then >= 1000cc injectors for e85 (probably $150 after upgrading and selling yours), then cams ($250-$400). Skip the cam gears.
Skip the injectors if you don't want to do e85. First link, then cams. If you don't want to get dsmlink, get a chip that is basically tuned for your injectors.
Old 04-09-2009   #6
2g Monson
2g Monson's Avatar
Alright thanks guys, I'll prolly go with the dsmlink to start out then see how the funds are because i gotta get a 1g running still this summer yet
Old 04-10-2009   #7
Hookers and blow. That is all. haha
Old 04-10-2009   #8
^hahaha.
Link FTW. I run 264/272 combo powerband is awesome.
Old 04-10-2009   #9
shit, i'd be half tempted to do what Shane did, and just have a chip for mara's car, on a stock ecu..still has NLTS, Antilag, etc..and makes good power. I can contest to it from last night!
-A. Swift
Old 04-10-2009   #10
Rob?
Anyway, DSMlink is nice because timing can be adjusted if need be. The cams are also good to increase the power band .
Old 04-10-2009   #11
2g Monson
2g Monson's Avatar
Yup its Rob, and is there a certain brand for cams that is better then any other?
Old 04-10-2009   #12
4seasons69
4seasons69's Avatar
hks always makes really nice stuff. i just put brian crowers in mine cause they were cheaper
Old 04-10-2009   #13
FP also makes good ones too, or HKS.
Old 04-10-2009   #14
hks272's and dsmlink, [/discussion]
Old 04-10-2009   #15
311evo
311evo's Avatar
All of the Above, especially the hookers and blow.
Old 04-11-2009   #16
HKS has a 10+year solid reputation. Crowers are good if they are sized correctly, FP makes some great products as well.
Old 04-11-2009   #17
The Brian Crower cams are cheap, but they work, and they are not regrinds.
Old 04-11-2009   #18
v8klla
v8klla's Avatar
I have to agree with the responses thusfar, DSMlink is a must and there is definitely some horsepower to be freed up with a camshaft upgrade. Larger injectors and E85 is also a great option. In regards to cam gears they would be pretty much for show only unless you plan to degree in the camshafts.
With that said, let me know if we can be of any assistance with your upcoming modifications We can offer a pretty healthy Mitsustyle discount on DSMlink, I have Brian Crower cams and FIC injectors in stock, and just about anything else you can imagine is just a few days away
Chris Carey
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 04-11-2009   #19
One more vote for Link. If you get Link, a wideband IMO is something you should get to go right along with Link. That way you can just tune it yourself for the most part right out on the street.
Old 04-11-2009   #20
v8klla
v8klla's Avatar
I concur, a wideband is an invaluable tool. You can get away with an Innovate 3769 unit for like $169.99 without a display and be able to log AFR in DSMlink!
P: 763-545-3800
