Old 04-13-2009   #1
TsiEagleTalon92
TsiEagleTalon92's Avatar
Drives: 2022 Hyundai Palisade
Fidanza Torque Spec
Anyone off hand have torque specs for the surface plate on an aluminum Fidanza flywheel?
And the flywheel to the block? I remember it being 96ft/lbs or so.
Old 04-14-2009   #2
CarRacer
CarRacer's Avatar
Drives: 91 Galant VR4
Re: Fidanza Torque Spec
I just did mine last night. I torqued the flywheel to the crank at 100 ft/lbs with red loctite.
For the pressure plate I used 30 ft/lbs.
Are you referring to the replaceable surface for the "surface plate"? That I'm not sure on, I bought a new flywheel.
CarRacer is offline   Reply With Quote
Old 04-14-2009   #3
~10lb/ft with a little loctite. Also the torque spec for a 6bolt is 96lb/ft and a 7bolt is 55lb/ft. I torque a 6bolt to 75 with red thread locker so the bolt does not break.
Old 04-15-2009   #4
TsiEagleTalon92
Thanks a ton guys, I needed both of those.
