Old 04-16-2009   #1
CarRacer
CarRacer's Avatar
Drives: 91 Galant VR4
FS: 1G 7 Bolt Longblock For Core
Selling the 1G 7 bolt that came out of my GVR4. It came in the car, so I have no idea what the mileage was or when the motor was put in. The motor DOES NOT run right now. An oil cooler line popped and dumped all of the coolant. I tried limping the car home like a dumbass and got the motor extremely hot. Based on the exhaust ports, the head gasket is toast at minimum.
There are a few good things though. The head has zero broken studs in it. The valve cover is not cracked and has no stripped threads. The oil pan turbo drain has a -10 AN bung welded on it, so the stock drain will not work.
I'm looking to get $150 for it as you see it. Motor is located in Prior Lake.
CarRacer is offline   Reply With Quote
Old 04-21-2009   #2
CarRacer
CarRacer's Avatar
Re: FS: 1G 7 Bolt Longblock For Core
Bump. Head, valve cover, and cams are all worth money. Toss me an offer.
Old 05-04-2009   #3
CarRacer
CarRacer's Avatar
$50. Come pick it up.
Old 05-08-2009   #4
CarRacer
CarRacer's Avatar
SOLD! Thanks for the space.
