Old 04-27-2009   #1
LaunchHard
LaunchHard's Avatar
Feeler: Precision 50 trim turbo
I have a precision 50 trim turbo that i purchased about a year ago and has less than 500miles on it, and i have reputable sources that can back me on that. I've been on and off the dyno over the past two weeks with misc. problems, and now that my car is pretty much done i found out from shane that im missing an extra ~50hp because something in my car is maxed out, and its most likely the turbo. The turbo has not seen full boost off the dyno. I'm curious to know what its worth so that i can determine what the difference will be between this one and a new one.
It made great power at 20psi and held all the way across, but when we pushed it up to 28 something got topped out and it dropped to 26psi by 7k. It has the smaller compressor housing on it, which may be the cause of it topping out. The turbo's mint, so let me know what you think i can get for it.
Im not near the turbo currently, but im pretty sure the part number is 200-5031B. Here's the link to precision.
http://www.precisionturbo.net/small-...bochargers.php
Thanks for the help.
Old 04-27-2009   #2
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Re: Feeler: Precision 50 trim turbo
Instead of scraping it why not just get a bigger compressor cover. I think the E cover, which flows alot more is only $100 from PTE.
Old 04-30-2009   #3
OldSchoolMotors
What kind of numbers did it make , and how much are you looking to get for it ?
OldSchoolMotors is offline   Reply With Quote
