Old 05-03-2009   #1
Clutch Opinions
I'm currently running a Fidanza 4.3 clutch. It's a sprung 6-puck that claims to be able to hold somewhere around 650ish tq. It's holding my power real well, like on a 4th gear pull. No slippage.
But today was when I really started launching with this clutch, and it did not perform anywhere near what I would have hoped. Just the slightest slipping of it on a launch, and it slips through all gears for the entire run. It can hold tons of power, but if it can't take a launch then it's not much good to me.
So here I am now, looking for a new clutch, and open to hear what anyone has to say.
I'm looking at 4 or 6 puck ACT 2600's, 2900's, Competition stage 5, Clutch Master stage 5.
Keep in mind, that I do NOT want to go with a twin disk, so don't go there.
I'm thinking about going with a non-sprung hub. It may be a little bit rougher on the street, but I think the lack of a sprung hub may help avoid slipping it off the line, which should hopefully reduce the chances of me running into the issue I am.
What clutch was Shane running when he ran his 10?
Old 05-03-2009   #2
Re: Clutch Opinions
My vote goes for the Comp Stage 5, or the Fidanza 5.4 if you want a solid hub.
Old 05-03-2009   #3
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
Re: Clutch Opinions
I would go 2900, 3200, or Twin disk at your level, imo
Old 05-03-2009   #4
Re: Clutch Opinions
I typically try to avoid ACT. Just haven't been all that happy with them in the past. But I may call them and ask them about their 2900 PP. I heard a couple people mention something about them having a new design on the 2900PP that allows for a lighter clutch pedal.
Twin disk is still something I'm really not interested in going with at this point in time.
Also that Fidanza 5.4 is a sintered iron disk. I've never felt one, but they sound harsh, so I'm a bit hesitant on that one.
Old 05-03-2009   #5
Re: Clutch Opinions
The 5.4 would definitely be rough on the drivetrain and not be much fun on the street.
Old 05-03-2009   #6
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Clutch Opinions
I have the act 2900 with a sprung 6 puck and it seems to be fairly similar to the feel of a 2600 and holds good for what I have been able to put at it so far. Not too bad pedal pressure and drivability.
Amsoil Dealer
Old 05-03-2009   #7
Re: Clutch Opinions
Right now I'm honestly leaning towards that, even though I told myself I was going to stay away from ACT.
Old 05-03-2009   #8
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: Clutch Opinions
Didn't they redesign their pressure plate and clutch disks lately tho that took care of previous problems?
Amsoil Dealer
Old 05-03-2009   #9
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: Clutch Opinions
I've been running the ACT 2600 with a 6 puck sprung disk for about 2 years. Been workin great for me. I say go for the 2900 with the 6 puck
-1990 Mitsubishi Cyborg 4WD-
Old 05-03-2009   #10
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: Clutch Opinions
I think the 2900 6 puck combo is rated at like 595 tq as well. If you want, you can drive my car to see if you like the combo.
Amsoil Dealer
Old 05-03-2009   #11
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: Clutch Opinions
I know whatever the rating is of the PP add 100tq onto it if you get a pucked disk..
Old 05-03-2009   #12
Re: Clutch Opinions
I'm in the same boat as Brandon. My 2600/street disc slips at the strip, and slips in fifth on the highway at WOT. I have an old, but brand new 2900 I was considering until I just read you guys stating that they redesigned something or another.. Can you expand on that? Wondering if I should consider using or not. Was also considering just trying a 6 puck with the current 2600 PP.
Old 05-03-2009   #13
Re: Clutch Opinions
I like my competition clutch stage 4. I have about 3k miles of very hard street driving on it and on trip to the track with 11 passes on it. Its held up great to the abuse and it was super cheap. Granted you make close to 100 tq/hp more than me I don't know if you can compare much, but I figured one more opinion never hurt.
Old 05-03-2009   #14
TsiEagleTalon92
TsiEagleTalon92's Avatar
Drives: 2022 Hyundai Palisade
Re: Clutch Opinions
I might be able to vouch for the lighter pedal on the 2900. I just got my car back together and it seems to me as if it has less force to put into it than my 2600 did.
Old 05-03-2009   #15
Re: Clutch Opinions
The Comp Stage 4 or more or less equivalent to his Fidanza 4.3. Great clutch, but 2 years of use + Brandon's power was just too much for it I guess
Old 05-03-2009   #16
Re: Clutch Opinions
Im going to ignore what you've said and say GET A TWIN!
Way back when shane ran his 10 i think he was running an AMS twindisc if memory serves.
Old 05-03-2009   #17
Re: Clutch Opinions
Forgot about that, I think you are right.
But I agree with Brandon.. No wanty a twin.
Old 05-04-2009   #18
Re: Clutch Opinions
The iron clutches are a bit tricky to drive on the street but if you get off it quickly you should have no welding problems. Unfortunately at the power level you are at, you will be pushing the limits on any single disc setup. You just don't have enough clutch diameter to harness the torque without having to give in pedal pressure (substantially) or longevity/driveability.
Old 05-04-2009   #19
Re: Clutch Opinions
Dxd?
Old 05-04-2009   #20
Re: Clutch Opinions
My opinion on sprung versus unsprung: If you drive it on the street more than the track, get sprung. If you drive it at the track more than the street, get unsprung. I've driven Jim's Evo on the street who had an unsprung clutch at the time and that was enough for me to decide that I'd never get an unsprung clutch for a street car.
It might be fine for you since yours is a weekend warrior, but at least drive such a car so you know what you'd be dealing with every time you sit in the seat if you haven't already.
