Old 05-08-2009   #1
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Question Why so much cheaper?
Hope I'm not .. but I probably am...
Why are BC 272 so much less expensive than HKS?? Are HKS really that much better?
ESchwanz is offline   Reply With Quote
Old 05-09-2009   #2
Re: Why so much cheaper?
Because BC stuff is junk Not sure about DSM's, but they're really good at losing power on Evo's and S2000's LOL
Old 05-09-2009   #3
craig made good power on the bc 280's. cheap made in mexico. hks gets more because it is HK$ but they have been doing them for ever and work great. my hks 272's have been in 3 cars now
Old 05-09-2009   #4
Just because the numbers are 'the same' does not mean the cams are the same. Specs are different, manufacture is different, etc. For a DSM, HKS 272s or nothing imho.
Old 05-09-2009   #5
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
so in other words the HKS are worth the extra money.... thanks... I'll keep trolling for a used pair.
Old 05-10-2009   #6
Also, correct me if I'm wrong, but the BC cams are regrinds, whereas the HKS cams aren't.
Old 05-10-2009   #7
If you are ok with running small cams in your car...
Check out FP's cams.
Old 05-11-2009   #8
v8klla
v8klla's Avatar
Brian Crower cams are new camshafts, not regrinds. When installed / degreed properly we have had good luck with the BC cams on the DSM platform as a cost effective upgrade. However, as was mentioned above the numeric designation is almost meaningless as there are several different specs that cannot be determined from the "272" designation. If you are looking for a low cost performance upgrade BC is a good choice, but if you want the best performance I would look to either FP or Kelford...
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 05-11-2009   #9
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
It depends on the application. They're not bad for the money. I've not seen them lose any power on Evos in person.
'04 Honda Ricer: stock
Old 05-11-2009   #10
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
I've had them in my car for the passed 2 years. Working great for me. I didn't degree them either.
-1990 Mitsubishi Cyborg 4WD-
Old 05-11-2009   #11
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
The BC's are on par with my WebCams
Old 05-11-2009   #12
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
just put in VTEC camshafts, i hear they work awesome. lol.
OP, I'm getting the BC camshafts for the galant just because i've seen them perform pretty well. once i get an Evo, i'll go to the kelfords or FP camshafts.
ლ(ಠ益ಠლ)
