Old 05-17-2009   #1
FS: 1992 Plymouth Laser, With extra parts.
Year: 1992
Make: Plymouth
Model: Laser
Trim package: RS AWD
Transmission: Manual, 5 speed
VIN: 4P3CT44U7NEO16990
Build date: August 1991
Title: Clean and in-hand. The registration is current.
Mileage: 97,236
Vehicle history: I purchased this car in September of 2004 from a local here in Ames. Prior to that, he had purchased it off of eBay from someone in Chicago. I have a folder full of paperwork from the last owner (eBay transaction record, parts receipts, etc.), however, I can not seem to locate it. When I do find it, it will be provided to the new owner. The car was last run on July 22, 2007 when it was trailered to my house from my parent’s and driven off of the trailer into my driveway. I occasionally drove it from the time of purchase until it was parked in my driveway.
Exterior color: Red
Exterior condition: The exterior has seen better days. The last owner had someone back into him, which is why the left fender, door, and quarter panels are dented up. There are mulitple spots of rust as is typical with DSMs of this era. The pictures outline the details pretty well.
Interior color: Gray cloth.
Interior condition: The interior is in ok condition. It had a junk alarm system installed in it when I purchased the car. I removed it about 2 years ago but used butt splices to link everything back together. Ideally, these splices will be removed and the connections soldered with heat shrink. The interior does need a good cleaning as I have never really cleaned it. The trim panels are disassembled in the hatch area.
Mechanical condition: The 1-2 synchro is shot in the transmission. It does blow blue smoke which I suspect is a result of blown valve stem seals.
Modifications: K&N air filter, Magnecor spark plug wires, NGK plugs, eBay strut tower bar.
Summary of extra parts:
1. Thermal R&D stainless cat back exhaust, 3”
2. 3” test pipe, Unknown brand
3. 2.5” downpipe, Unknown brand.
4. Partially assembled transmission.
a. Sold to me as from a 1992 AWD Talon.
5. Assembled transfer case.
6. 1G BOV.
7. Cam gears.
8. Coil pack.
9. Disassembled transmission.
a. Sold to me as from a 1990 FWD Laser.
10. Extra red Laser door.
11. Spare tire.
12. (4) brake flow divders/proportioning valves.
a. Sold to me as non-ABS.
13. (2) k-type EGT probes, 1 new.
14. (3) 1G throttle bodies.
15. (2) boxes of Clevite bearings.
16. 1G O2 housing.
17. Red 1G tail light center piece.
18. 2 pod, 1G full pillar gauge pod, Stewart Warner, New.
19. (4) valve covers.
20. “Titanium” valve cover.
a. Purchased from tkrPerformance.
21. OEM clutch master cylinder, New Mitsubishi.
22. (3) spit radio bezels.
23. 1G EPROM ECU, ’91-’94.
a. Purchased from Steve Hill.
24. 6 bolt cylinder head, Bent valves.
a. Purchased from jd1828. For those of you historians, this head was on the red Talon that Mike Thomas (Raptor) found for his brother to drive many years ago.
25. Elite Autosport MBC, New.
26. SPAL fan, New.
27. 14B, Cracked turbine housing.
28. Non-ABS brake lines.
29. Balancer shafts.
30. (4) exhaust manifolds.
a. 1 manifold is a mint 2G manifold that was the original factory manifold on Brian Barton’s (aka BrnOutKing/SlowWhite) GST or GSX, can not recall which.
31. Miscellaneous gaskets.
32. Miscellaneous interior clips.
33. 2G eBay Injen intake.
34. 2G throttle body elbow.
35. Stewart Warner boost gauge, PN 114544, New.
36. Stewart Warner EGT gauge, PN 114408, New.
37. FFWD copper EGT blockoff plate kit.
38. Dynamic Motorsport Engineering 1G rear camber adjustment kit, New.
39. FFWD turbo/O2 bolt kit, New.
40. Miscellenaous poly bushings, New.
41. 1G black leather interior.
42. Extra hatch interior panels, Originally were in MAP's 1G when it was owned by Mike Thomas (Raptor).
Price: $1,000. The parts alone are worth $1,000.
Terms: The car and parts are sold as is, where is. No transportation is available. The car and parts must be picked up in Ames, Iowa. I am not interested in trades. Payment must be made in cash. I am looking to sell the car and all parts in one lot.
Questions? Please e-mail me at jmbolson@gmail.com, post in this thread, or PM me. This website is blocked at work so responses via posts or PM may be delayed up to 24 hours.
Name:	Picture 001_compressed.jpg
ID:	8647   Click image for larger version
Name:	Picture 002_compressed.jpg
ID:	8648   Click image for larger version
Name:	Picture 003_compressed.jpg
Name:	Picture 004_compressed.jpg
ID:	8650   Click image for larger version
Name:	Picture 005_compressed.jpg
ID:	8651   Click image for larger version
Name:	Picture 006_compressed.jpg
Name:	Picture 007_compressed.jpg
ID:	8653   Click image for larger version
Name:	Picture 008_compressed.jpg
ID:	8654   Click image for larger version
Name:	Picture 009_compressed.jpg
Name:	Picture 010_compressed.jpg
Old 05-17-2009   #2
Re: FS: 1992 Plymouth Laser, With extra parts.
Name:	Picture 011_compressed.jpg
ID:	8657   Click image for larger version
Name:	Picture 012_compressed.jpg
ID:	8658   Click image for larger version
Name:	Picture 013_compressed.jpg
Name:	Picture 014_compressed.jpg
ID:	8660   Click image for larger version
Name:	Picture 015_compressed.jpg
ID:	8661   Click image for larger version
Name:	Picture 016_compressed.jpg
Name:	Picture 017_compressed.jpg
ID:	8663   Click image for larger version
Name:	Picture 018_compressed.jpg
ID:	8664   Click image for larger version
Name:	Picture 019_compressed.jpg
Name:	Picture 020_compressed.jpg
Old 05-17-2009   #3
Name:	Picture 021_compressed.jpg
ID:	8677   Click image for larger version
Name:	Picture 022_compressed.jpg
ID:	8678   Click image for larger version
Name:	Picture 023_compressed.jpg
Name:	Picture 024_compressed.jpg
ID:	8680   Click image for larger version
Name:	Picture 025_compressed.jpg
ID:	8681   Click image for larger version
Name:	Picture 026_compressed.jpg
Name:	Picture 027_compressed.jpg
ID:	8683   Click image for larger version
Name:	Picture 028_compressed.jpg
ID:	8684   Click image for larger version
Name:	Picture 029_compressed.jpg
Name:	Picture 030_compressed.jpg
Old 05-17-2009   #4
Name:	Picture 031_compressed.jpg
ID:	8687   Click image for larger version
Name:	Picture 032_compressed.jpg
ID:	8688   Click image for larger version
Name:	Picture 033_compressed.jpg
Name:	Picture 034_compressed.jpg
ID:	8690   Click image for larger version
Name:	Picture 035_compressed.jpg
ID:	8691   Click image for larger version
Name:	Picture 036_compressed.jpg
Name:	Picture 037_compressed.jpg
ID:	8693   Click image for larger version
Name:	Picture 038_compressed.jpg
ID:	8694   Click image for larger version
Name:	Picture 039_compressed.jpg
Name:	Picture 040_compressed.jpg
Old 05-17-2009   #5
Name:	Picture 041_compressed.jpg
ID:	8697   Click image for larger version
Name:	Picture 042_compressed.jpg
ID:	8698   Click image for larger version
Name:	Picture 043_compressed.jpg
Name:	Picture 044_compressed.jpg
ID:	8700   Click image for larger version
Name:	Picture 045_compressed.jpg
ID:	8701   Click image for larger version
Name:	Picture 046_compressed.jpg
Name:	Picture 047_compressed.jpg
ID:	8703   Click image for larger version
Name:	Picture 048_compressed.jpg
ID:	8704   Click image for larger version
Name:	Picture 049_compressed.jpg
Old 05-17-2009   #6
Just to clarify, is this car in running condition so it can be driven home or will it have to be trailered? Unless I'm missing something it wasn't that clear.
Old 05-17-2009   #7
I am selling the car in non-running condition, with it last being run on July 22, 2007. I have not tried to start it since. It will need to be trailered.
Old 05-18-2009   #8
GREASEMONKEY
GREASEMONKEY's Avatar
Moon Lander Champion!
Drives: 92 TSi
Im interested, I will shoot you a PM when i can figure out the money / trailer situation..
Old 05-18-2009   #9
Sell the black leather seperately?
Old 05-18-2009   #10
Thank you for the many offers on purchasing individual parts but I am not interested in seperating anything from the lot due to time resources.
Old 05-21-2009   #11
The car will be going on craigslist on Monday.
Old 05-29-2009   #12
Will consider reasonable offers.
Old 05-31-2009   #13
So you never did find a good use for the clevite bearings? GL with the sale.
Old 06-02-2009   #14
Negative, I never really got anywhere with anything on the car, and I've had it for almost 5 years. Now I'm getting married and the car needs to go.
Old 06-09-2009   #15
I've had multiple e-mails requesting more information but the car is still available.
Old 06-18-2009   #16
So what price will sell this package?
Old 07-01-2009   #17
$850
Old 07-10-2009   #18
Sold!
