Old 05-19-2009   #1
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
WTB Exhaust side turbo housing for 16g
Mine has a busted stud & is leaking badly & i need to fix this soon.
heard its a bstrd to drill out...
Maybe its just time for a new one if I can find a used one here that will work.
Thanks for looking.
What do ya think of the FP18G6SL2 ?
Maybe I should look at the TDO6 Frank 4 60 trim that FS hmm...
Or this looks like an option --->http://www.maperformance.com/bullsey...bocharger.html,
or
http://www.maperformance.com/bullsey...arger-dsm.html
any input would be appreciated. Thanks!
ESchwanz is offline   Reply With Quote
Old 05-19-2009   #2
Re: WTB Exhaust side turbo housing for 16g
Just unhook the turbo, take the stud out with some pliers/vicegrips, and reinstall with a new gasket and stud/bolt. I assume you meant exhaust leak.
If you're lazy you might be able to just take out the current three holding it on and let it sag a bit to get a pliers on the broken stud and twist it out, then you wouldn't even have to drain the coolant.
