Old 05-21-2009   #1
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
WTB: 1G Coolant temp sensor
I need the sensor that reports to the ECU. It's for my Colt but I'm pretty sure they're all the same.
Needed ASAP, trying to sell the Stealth and I need a 2nd car to drive. I tried the parts store and the one they list doesn't plug in. I'm not into custom wiring the damn thing unless I have no other choice.
Old 05-21-2009   #2
blageo23
AWD4G64
blageo23's Avatar
Re: WTB: 1G Coolant temp sensor
I have one. stop up at primo performance anytime and pick it up. its free
1998 Spyder AWD
567hp
490tq
Old 05-21-2009   #3
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
OK, just for my peace of mind, can you describe it? The one off the car has a plastic plug/shroud around 2 narrow connectors. The one the parts store and mitsu have for my car has 2 wider prongs about the width of fuse connectors.
Old 05-22-2009   #4
blageo23
AWD4G64
blageo23's Avatar
the one I have looks like this...
only difference is that the one I have has white plastic not black
1998 Spyder AWD
567hp
490tq
Old 05-22-2009   #5
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Perfect, that's exactly the one I need. Why the heck do Mitsu and all the parts stores think I'm insane and try to sell me a different one?
Old 05-22-2009   #6
bluedeath
Drives: 1999 Chevy S10
isnt that the one that goes in the bottom of the radiator? doent that only turn on the rad fan? i may be wrong....
bluedeath is offline   Reply With Quote
Old 05-22-2009   #7
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
just take it off and goto autozone. I've gotten one there before, I swear it was like $3.
'04 Honda Ricer: stock
Old 05-22-2009   #8
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
It's the one that reports to the ECU, my logger reads between -15 and 8 degrees coolant temp right now. It goes into the top of the thermostat housing on a Colt.
I took it to Advance Auto Parts and the guy couldn't find it. He checked every sensor for every make and model Dodge/Mitsu/Eagle that ever came with a 4G61 or 63 motor. The one he sold me screws in, so technically it's the right sensor, but it doesn't have that plastic plug on it, and in no way shape or form plugs in.
Old 05-22-2009   #9
bluedeath
on my laser, the small one on the t housing is for the guage, big one with 2 large perpendicular blades is ecu, and the one in the pic above goes in the rad to switch the fans on. i go to advance auto, and i had to explain the exact location of the sensor on the rad and what it looked like for them to find it in the comp. they didnt even know there was one there. odd.
Old 05-22-2009   #10
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
On the Colt there are 2 on the thermostat housing, one top (the large one) and one bottom. The radiator cap is on the radiator. I was told the large one on top of the t stat housing went to the ECU. I will unplug it and check the logger to verify.
Old 05-24-2009   #11
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Good news everyone: I'm an idiot.
So I unplugged the top sensor to see if the logger reading would change, it did not. I became suspicious of my previous theory and started poking around. Well, turns out its the bottom sensor on the t-stat housing that's feeding the ECU. Nothing wrong with the sensor either, I just smashed the plug installing the intake/ic piping. That's why it sometimes works but usually doesn't.
Learning is fun.
