Old 05-21-2009   #1
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Project: XP Stealth
Well, since I started putting parts on my 93TT today, I figured I'd start my thread. I have the front suspention and brakes swapped over. I have the left rear Ksports swapped as well, need to do the upper control arm and brake as well. Other than that, I haven't done a ton to it. It's filled with parts.
A little backround on the car itself. I bought it back in 2006. This was my second 3S, first one that ran. I drove it for a short while, until the water pump locked up. Nothing bad happened to the engine besides some minor over heating. But after seeing the poor state of affairs with the T-belt I pulled the engine for further inspection. Pulling the main girdle off the center two main bearings showed copper.
A build with pistons and all sorts of stuff was started at this point. I collected a lot of parts, but very few ever made it on the car. I also did a lot of work to the car. Everything was pulled out, all sound deadening was removed, all wiring that didn't run the engine or lights was removed, pop up head lights were converted to manual pop up, and I'm sure a few things I've forgotten about. Then my 92TT came up cheap and I started focusing on the driver mod more and the budget and motivation for this car dwindled.
Since the 92 TT is dead, and approaching gone, the 93 will be coming back to life. It's only just though, the 92 "stole" a lot of parts from the 93 when it ran into some major problems. So, that's a fair amount of the story of why I'm building my race car.
Goals for the car:
Initially under 3000lbs, eventually under 3000 lbs with driver.
Power: Mid to upper 400's. Into the 5's if I go for E85.
After that who knows. Make it turn better.
For anyone wondering why it's "Project XP Stealth", here's why. XP is an autocross class for cars. It stands for X Prepared, and is the fastest Prepared class there is. It has a TON of allowances for modifications in the rules, which also means to be competitive, you NEED to take advantage of every allowance in the rules, because someone else will, and beat you because of it. Due to some of the mods already done without consideration for the rules, this is the class that my car will fit into. I could attempt to undo the mods, but there are potential problems with that. And I was half considering running this car in this class anyways, so why not?
I only have to beat Miata's and BWM's any ways, should be no problem for an oversized Mitsu right?
Old 05-22-2009   #2
Re: Project: XP Stealth
This is gonna be sweet! Let me know if you need a hand anytime Ryan.
Old 05-22-2009   #3
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Good luck man! I hope this turns out the way you envision it.
Are you going to need a tow rig now too or you still going to be a trooper and drive it to events?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 05-22-2009   #4
Yay! Can't wait to see progress pics!
Old 05-22-2009   #5
MustGoFaster
At least for the foreseeable future it will be driven to events. Working power windows, + working lights/turn signals = street legal enough to take my chances every once in a while.
Old 05-22-2009   #6
^ I agree! This project sounds pretty fun, good luck!
What color is it?
Old 05-22-2009   #7
Sweet project! I was excited to maybe see a bimmer in your garage, but this will have to do.
Old 05-22-2009   #8
green
Old 05-22-2009   #9
green
They are always green!
Old 05-22-2009   #10
Sounds like a pretty sweet project!
Old 05-22-2009   #11
MustGoFaster
I did very little with the 93 today, but the 92TT is 100% ready to be dragged off to never never land. I cleaned it out a little, mostly put scrap metal into the 92 and set aside a bit of aluminum to make a few $$. The front sub frame piece showed up, so I should be able to assemble the trans and drop the motor/trans in tomorrow.
Thanks for the interest guys, hopefully it won't take to long to get it up and running.
Old 05-23-2009   #12
This is going to be awesome. Your sister sounds like a pretty funny person, haha.
Old 05-30-2009   #13
MustGoFaster
Well, I dropped the engine & trans in today. I had to Heli-coil two holes on the front sub frame, and working a bit of over time slowed me down durring the week. I also did the mod to my power steering pump so it shouldn't cut out at high revs any more.
I put the trans together a while ago with some upgrades. I now have a torsen style front diff (stock is open diff) and an upgraded output shaft. My "new" trans also has a good VCU in the center diff. The old one had a bad one. I did a new input spool on the T-case as well. With the t-case brace, at my power level the drive train should be able to handle anything I can throw at it.
Old 06-02-2009   #14
MustGoFaster
Ok, I need to get cracking on this thing. I want to be driving it for the intermediate school on the 14th.
I have all the the drive train installed, still need to fill the trans. After that it's just hooking up the engine stuff and getting it aligned. I also need to have the IC fixed, which would be just about the only hold up I think. I have some new pipes on order, hopefully they get here in a timely fashion and I can get things all wrapped up.
At this point my focus has shifted from getting all my mods and parts done and installed, to getting it driving.
Old 06-03-2009   #15
Should be sweet!
Old 06-03-2009   #16
MustGoFaster
I forgot about a few parts that need to be done custom, but I don't think I will have any problem getting them done. I did start it for a few seconds today, just to make sure everything works.
Old 06-04-2009   #17
Pics?
Old 06-04-2009   #18
MustGoFaster
Rule of thumb for the project: If it doesn't make it go, stop or run it's not there. It does have working exterior lights, and windshield wipers, they are need to be street legal.
Trans:
Interior (minus stock seats for now):
More:
http://www.mitsustyle.com/photopost/...o=2761&cat=598
Old 06-04-2009   #19
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
What's that thing weigh gutted like that?
Old 06-04-2009   #20
MustGoFaster
Not sure yet. Hoping close to if not slightly under 3000 lbs, as ridiculous as that sounds for a gutted car.
