Old 05-24-2009   #1
Broadviews
Drives: 1995 eclipse gsx
1995 eclipse gsx 1500obo
need gone ASAP lanlord is getting mad, make offers (no super low balls please)
i have for sale a 1995 eclipse GSX awd turbo, engine does need a rebuild from spun rod bearing
The good:
-14b turbo uprgade
-new clutch about 3000 miles on it
-all new brakes about 1000 ago
- injen intake with K&N filter
- new fuel pressure regulator
- boost gauge
-hot wheel 5 spoke rims brand new back tires, front ones need replacing they are pretty bad
- new passanger front wheel bearing
- New valve lifters
- comes with but not on the car: light weight flywheel 8lbs., after market side skirts, 97 front bumper, 97 headlights, new starter, and a few random interior peices
the bad:
has 186,000 miles
strut towers have a hole rusted through them (easy fix just weld a plate over the hole)
has spun rod bearing so it needs a rebuild or a 6-bolt swap
broken door handle on drivers side
email me at gixxer750r@gmail.com cause i dont have time to log onto here to much but ill try
ID:	8756   Click image for larger version
ID:	8757   Click image for larger version
ID:	8759   Click image for larger version
ID:	8760   Click image for larger version
Broadviews is offline   Reply With Quote
