Old 05-27-2009   #1
DoughtCom
It's deluxe son... deluxe
DoughtCom's Avatar
Drives: Your mom
Project P00n (Exotic Killer)
I'll update this later, but wanted to start the thread. I have some dyno graphs on this car and I'll post the mod list right now.
Current mod list:
Greddy Turbo Timer
TurboXS Manual Boost Controller
Buschur Catback 3" Exhaust
Trustz Blue Gauge Overlay
Ferodo DS-2500 Brake Pads
Rotorpros Crossdrilled/Slotted Rotors
FF/MAP Ported coated black Exhaust Manifold
K&N Typhoon Intake
AMS Mini Battery Kit
K&N Valve Cover Breather Filter
255 Walboro Fuel Pump
Grouppe-S 3 55mm Gauge Pod
Buschur Manifold Cover
AMS Front Mount Intercooler
52mm Prosport Gauges (EGT, Boost, Fuel Pressure/Temp)
Rexpeed CF Gauge Overlay
Rexpeed Gourney Flap
Buschur Shifter Bushings
Kracka Vents (you know it!)
Lilliput 7" LCD Touch Screen
HP Laptop for carputer core
Horse Power Freaks LICP
Smoked Sidemarkers
360gram Shifter
250GB Drive
Nisie UICP
Carbon Fiber Headlight Eye Lids
1st Tune @ DB Tuning 04/26/08 (304WHP/296FTQ)
Tien S-Tech Lowering springs
RRE X-Clutch 3000
MAP 2.5/3" O2 eliminator down pipe
Autometer Single Gauge Pod
BLOX Motor Mount
Buschur Bullet Test Pipe
FIC 850cc Injectors
Evo VII Center Console with custom routing for iPhone
Mild ported turbine housing
Added: 07-02-09 (Thank you Hughes and Scheide for all your help!)
(MAP) Stage 3 Ported Head/5 Angle Valve Job
(MAP) Version 2 Ported/Coated Intake Manifold
(Mil-Spec) Ported 65mm Throttle Body
(MAP) Intake Manifold heat barrier gasget
Shifter Base Bushings
ARP Head Studs
FP4R Cams/Springs
GM Air intake Sensor
To come later:
Samco radiator hoses
LC-1 Wideband
4 Bar MAP
Goal is 400AWHP on MAP's dyno. Hughes and I have high expectations of this car, only because we've put so much work into it and he knows I'll go on a killing spree if it doesn't perform well. It's beaten DB9's, Ferrari 430's, Porsche GT3s, etc. I'm just tired of losing to Vipers so hopefully this will get me to where I want to be, if not... it's time for a BBK Lite (or most likely an FP White) and a 9000 RPM redline.
Carputer/Gauge Setup.
Evo VII center console
Car in front of my workplace in Texas
Car downtown for lunch at the Lyon's Pub
Car at my house in Texas EV0 FTW son.
MAPerformance's awesome ported exhaust manifold.
Scheides porting my turbine housing
Block cleaned..
Polished AMS FMIC
Head almost put back together with FP4Rs after MAP's porting job.
2010 Evo X GSR
1997 Subaru GC8 STi
