Old 06-01-2009   #1
1992 Tsi AWD 446AWHP
Take a look at my craigslist ad:
http://minneapolis.craigslist.org/ra...396352891.html
For the price you aren't going to get a better performing car.
I have but a lot of time, money, and effort into making this car into a very nicely modded 1G AWD. Almost every aspect of the car has been modified, the suspension, brakes, exterior, interior, and of couse the engine and drivetrain. The engine bay is where my effort was mostly applied. Just recently won 2nd Best 1G at the 20009 Mitsu Cookout. The car overall is in very good condition for the mileage. This is also an extremely reliable car, I have no worries! I drove this car 4 hours to Brainerd, ran 10 passes down the drag strip, and drove back home! It runs great!
1992 Eagle Talon TSI AWD 5 speed
Runs on E85
NO RUST
6 bolt engine/ 4 bolt rear end
145,000 miles (15-20K on engine!)
Great condition interior with tan leather
No A/C or power steering
All receipts since I've owned it (it was stock when I got it)
Dyno tuned at DB Performance, made 446awhp/354tq (Fuel Pump limited)
Ran a best of 11.47@127mph @ 402awhp/335tq
99% of parts are from Mitsubishi; no parts store crap here.
Almost everything on the car was bought BRAND NEW
6 bolt engine, 4 bolt rear end
All maintenance stuff is done:
Brakes are new, belts,battery, timing belt/waterpump, fluids, hoses, etc. Pretty much everything. Drive this without worry!!
The Bad:
Left side parking brake cable broken, but right side works great!
The pushlock/AN drain tube seems to always have a small drip of oil on it, not a bad leak, just some seepage
Headliner sags, has been fixed twice before
Tear on driver's seat.
Current MODS.... Yeah, it's a long list.... Read it all!
Drivetrain:
Shephard Racing Stage 3 tranny rebuild, optional Chromoly shift forks, 4 spider
ACT 2600lb Pressure Plate
ACT 6-puck Ceramic sprung disk
ACT Xact flywheel
Silicone filled driveshaft carrier bearings
Suspension:
Ksport coilovers
Ingalls Engineering adjustable rear upper control arms
Suspension Techniques rear sway bar
Redline Shockproof
Pennzoil Syncromesh
Brakes:
1G big brakes: 2 piston front, and larger rotors
Silver painted calipers
Axxis Ultimate pads
Earl's stainless steel brake lines
Wheels/Tires:
225/45/17 BFG G-Force T/A KDW2's
17" 2g GSX rims painted black
Engine/Performance:
Brian Crower 272/272 cams
Rebuilt shortblock with new everthing from Mitsu
ACL Race bearings
ARP headstuds
Coppersprayed headgasket
Rebuilt head with all new valves, stem seals, 3 angle, decked
New style Magnus SMIM with Taco's
FP Race Manifold, TurboX ceramic coating
Holset HX40 Pro 6 blade, BEP .55 A/R housing TurboX ceramic coated black
Ebay SS 3" bolt-on V-band 02 housing with external wastegate, modded with v-band recirc TurboX coated
Tial 38MM MS-V v-band wastegate
Buschur Racing 3" stainless steel mandrel bent turbo back and test pipe modded with a v-band
Greddy Type RS Bov
Extreme PSI Street FMIC
Custom 4" cold air intake
K&N 12" long cone filter in fenderwell
14" SPAL Slim fan
Visteon/C&R Racing aluminum radiator
Prothane motor mounts
Cruise control deleted
A/C Deleted
Power steering Deleted
Emissions Deleted
Hallman Pro MBC @28psi
90 OFH with B&M external oil cooler and -8 lines
Fuel/Engine Management:
ECMLink V3 w/ GM Maf cable
Walbro 255HP fuel pump, rewired
Aeromotive AFPR
FIC Bluemax 1650CC injectors
FIC fuelrail
-6an from filter-rail-regulator
3" GM MAF
Interior/Exterior:
Tinted tailights (professionally done with automotive paint)
Ebay black housing headlights
Debadged
AEM Wideband
Prosport Electronic Boost
Prosport Premium Peak/Warning electronic oil pressure Really cool!!!
Lotek triple A-pillar pod
Black headliner
Dome light eliminated
Rear view mirror with map lights
Single DIN coin/cup holder
Alpine CD player
Misc Custom stuff!!:
Misc powder coated stuff
Chopped timing belt side motor mount
Painted engine bay black (took the engine out just for that!)
Reloomed engine harness and retaped
Black w/ rainbow flake powdercoated valve cover
Clear timing belt cover
Polished overflow bottle
stainless steel valve cover bolts
All underhood bolts new Mitsubishi Genuine zinc coated
And more I'm forgetting!
$8500 OBO!!!!!!!
651-675-7085
PM me for contact info or anything else!!!
ID:	8981   Click image for larger version
ID:	8775   Click image for larger version
ID:	8982   Click image for larger version
ID:	8778   Click image for larger version
ID:	8780   Click image for larger version
ID:	8980   Click image for larger version
