Old 06-16-2009   #1
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
What weight oil do you use?
And if you use something other than 10w-30 which is specified by the 1g dsm users manual, why did you switch?
Reason I ask, is my oil pressure is a little on the low side, which isn't too surprising for a high mileage dsm, and i've been thinking about switching to 10w-40 to boost it a bit until i get around to swapping out the oil pump. Is that a terrible idea?
Style's automotive engineer
Old 06-16-2009   #2
Re: What weight oil do you use?
10W-40 is fine to use and falls within Mitsu's spec for use during the warmer months. What is your oil pressure at during idle and hwy cruise?
Old 06-16-2009   #3
I use 15W-40. Reason is because I just see a lot of the other guys at similar power levels using thicker weights. And if it's working for them, then hopefully it works for me.
Old 06-16-2009   #4
I put 10w-30 synthetic in my quest because I got it for free at the dyno day, and it's working fine. But next oil change I'm going back to 20w-50 regular oil for the win.
Old 06-16-2009   #5
I have always used 10-30.
What would be the benefit of running heavier oil? Does not having balance shafts and not porting your relief valve make your oil pressure get pretty high with the heavier stuff too?
Old 06-16-2009   #6
I saw a big difference in 15w 40 vs. 10w 30. The newer stuff my oil psi was around 80 at cruising/pulls, and around 50ish at idle, or just below. Old 10w30 it would be around 25 at idle, and 75ish max under load. I ran the oil feed off the filter housing, and no restrictor, and could have been the reason why my turbo detonated, and shifted the center shaft over.
Old 06-16-2009   #7
When you start making some decent power you might want to goto some thicker oil to protect that munchgsx stage 1 motor you got.
Old 06-16-2009   #8
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Amsoil 20w50 with larger main bearing gap by using acl race bearings.
Amsoil Dealer
Old 06-17-2009   #9
Keith H
Amsoil 20w50 here as well.
Keith H is offline   Reply With Quote
Old 06-17-2009   #10
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
I did use 5w30 valvoline conventional at one point, but did not like how my lifters reacted. So then I went to 10w30 valvoline and it got better. Switched to valvoline full synthetic 10w30 and I leaked everywhere. lol
I plan to run full synthetic 10w30 once I get the car put back together.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 06-17-2009   #11
I run royal purple 10w-30 right now, but will be switching to Rotalla 10w-30 this weekend.
Old 06-17-2009   #12
Good choice
Old 06-17-2009   #13
Good choice
thanks
Oh I forgot to mention, I already run Rotella in my DD, I will be switching to rotella in the DSM this weekend.
Old 06-17-2009   #14
s1ngletracker
Drives: A BMW
Why Rotella?
Old 06-17-2009   #15
Its a good, proven, heavy-duty conventional oil.
Old 06-17-2009   #16
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Is it cheap? Or is it expensive like Royoal Purple and AMSOIL? And where do they sell it?
-1990 Mitsubishi Cyborg 4WD-
Old 06-17-2009   #17
Its priced like every other conventional, I think a gallon (4 quarts) is under $10 at Walmart.
Old 06-17-2009   #18
Yeah it's price is extremely reasonable. Right on par with other name brand jugs of conventional oil.
Old 06-17-2009   #19
s1ngletracker
Drives: A BMW
wow, crazy. For once something that people speak positively about that isn't stupidly expensive.
Old 06-17-2009   #20
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
So I should stop running Royal Purple and run this stuff?
